The Dyno sheet below is from my truck - 2015 Ram 1500 Sport QC. DS used it to Dyno tune a new PCM and then Dyno tested it to validate that tune. They then returned the truck to me with both PCM’s (old one in mopar box the new one came in).
I have to say, you guys are really going to be happy with the results from this tune!
My impressions after putting on only about 50 (spirited) miles since getting the truck back:
The truck as a whole, feels much lighter when driving. In comparison, I previously had a 2011 Ram R/T w the 4.10 gears & a DS 93 tune & I really did feel the extra weight in the accelerator pedal on my new 2015 QC. But now with this tune, I REALLY feel like I'm back in the R/T…even with the 3.21 gears & 8-speed tranny. This is just what this truck needed!
Throttle response is greatly improved. No more torque management delays & just an instant rush when pressing the go peddle at any speed or any gear.
Bye Bye MDS - it is shut off & I couldn't be happier about it. No more sounds of a helicopter following me around while cruising.
Acceleration is noticeably stronger in all gears/speeds & tire chirps are now a common occurrence.
I have a 185 degree t-stat already installed & it now runs cooler since the fans kick on a little sooner. I'm not sure what DS set the fan on temps to, but while driving around prior to the tune, I was still getting up to about 218 degrees, but so far with the tune 200 is the highest I have seen.
It is a little early to make a determination on how this tune will impact my gas mileage, but It is a full size truck and I didn't really buy it thinking about gas mileage anyway, it is just not a concern to me much, as long as I don't dip into single digits, which I really don't expect based on my past experience with their tunes.
Mike & the guys at DS were great to work with during this process they kept me updated with info & sent me pics along the way. If you have had any concerns that they were dragging this release out or not doing everything they could...DON'T! They are working REALLY hard at making this the best they can make it & including support for everything they can before releasing it to us. Trust me this means more to them than it does to us, as there name & reputation as a company is on the product and they are approaching the release as such.
I’m sure release is not far off now, and at that point you will be REALLY happy with the improvements they have made, and the possibilities of what can come in the future, as they keep improving after initial release.
