- Jul 17, 2012
- 9,421
- 4,703
- Conroe, TX
- 2014 Ram 1500
- Whipple Supercharged 422" Hemi
Sorry to cut the show short guys, but its not worth arguing in every thread.
So are you going to be selling unlocked PCM's with the Trinity? A package deal? Group buy? Or is this only going to be sold through Diablo?
That is what Hemifever is working on right now. Only a select few dealers are going to be allowed to sell the PCM's, so we are working with them to ensure we are part of that group. Sean flew down there Monday and Tuesday to talk with them about how the tuning is going to work, and who will be allowed to sell them. It sounds like it is very close, so hopefully we have some new info in the next few weeks.
I'm interested in this. I am assuming that the new PCM will be unlocked and that with it, we will be able to make adjustments on and on-going basis. The original post suggested that might not be the case.
I'm also ready to go (even though my truck hasn't been delivered yet).
Look at the scales on the sides...they are not the same.
MeanSrt - you near Delray?
That is the point. They didn't give you a sheet with SAE calculations. There are 8 or so different scalings. They gave you there inflated scaling.
I dont understand how changing a gear ratio can add more HP, wouldn't it just shift the curve?
The motor is not producing more HPs, if you could measure it on the crank, but as the power is being measured from the wheels as dyno does - different GRs affect the delivered power to the road.
You guys are seeing higher umbers on your dynos that we see down here. I think I remember you posting that your truck made 405hp, and I have customers down here with more mods that are closer to 380hp. Also, I have found the opposite of what you mentioned about gear ratios. Typically, the higher the gear ratio, the lower the dyno number. Its usually only about 5-10hp, but I have seen that trend going back to my 3rd gen that had more than 60 dyno passes on.
Viktor, I sent you a reply last night, but I'll shoot it over again. I was just asking if you needed a couple cleaning kits as well. I can throw them in for free if you need them.
As for the dynos, gearing is a lot like a tq converter. I've seen higher stall tq converters and high gear ratios consistently show lower numbers on the dyno but faster ET's at the track. The dyno is measuring how much power the engine is putting out. Your gears and converter simply help put you into the rpm range where the motor is making power. This is why they don't show any increase on the dyno even though they show major increases at the dragstrip.
i want this now! I neeeeeeeeeeed some tuning.... Diablo, please take my money!
