2015 Ram 1500 throttle body bolts stripped???
BEAST19
Replaced stock tb with Moe's performance 87mm tb ... barely tightened bolts and I think they are stripped!!! Any ideas to fix without replacing parts??
nateinva
Central Virginia
2011 1500 Laramie CC
5.7L
Hope you get it fixed. I stripped one of mine when installing my new TB. Doesn't take much.....
BEAST19
BEAST19
Interested in fixing without replacing intake manifold ... any takers?? Heard I can fill holes with resin and retap
BEAST19
BEAST19
Or just thought of trying a slightly bigger bolt.
BEAST19
BEAST19
How'd u fix urs? I'm lookin at a helicoil kit
Sickem
2017 1500-Express 3.92's w/ anti-spin
The best way to repair stripped aluminum is to drill it and use a threaded insert.
BEAST19
BEAST19
Mine is whistling . Have no choice but to fix
nateinva
Central Virginia
5.7L
I understand....I have a very slight sound I think is coming from the TB. It isn't loud and sounds like a turbo spooling at low RPMs.
Sickem
That part of the intake is plastic.
It will still work as long as you have enough material in the side wall. I think they are made by ez lock or something like that. We used to use them all the time back in my wrenching days.
nateinva
Central Virginia
5.7L
Good deal...
