reb0957
I have a 2016 with 50k miles.
Last weekend I was working in flower beds and played the radio in the truck while I was doing it, truck wouldn't crank so it was no big deal. Neighbor jumped me.
This week I have noticed that at random times when starting the truck the battery sounded weak. Like it just took a little longer than normal to start.
This evening the truck wouldn't start. I figured it was the battery. Got it started drove to AutoZone pulled the battery. Battery tests good.
Put the battery in the truck, test the whole system and it says starter is bad.
1. Am I correct the starter isn't covered under powertrain warranty?
2. How much of a PITA is this gonna be to change on a 4x4?
TIA
Also, without the truck running you can't shift it in neutral to push it outta the way to get a vehicle to jump it! UGHH technology
TIA
