2nd gear rpm swing feels notchy
mrtosh
I just picked up a 2012 Sport about 3 weeks ago and currently have about 850 miles on the truck. Love it so far but have noticed a strange notchiness to the rpm swing in 2nd gear. Almost like the rpm's hang for a second(generally around 2500 R's)and then pick up. The speedo doesn't appear to hang up. I only notice this under moderate throttle(maybe20-25%). Under any harder throttle load it swings fast through the revs like it should. It almost seems like the truck is deciding if it should shift or keep accelerating and it picks the latter. Anybody else notice this?
Thanks in advance!
jlb
MT
CTD
It looks like it has something to do with toque converter lockup because your speed keeps changing even when the tach hangs.
M
mrtosh
Normal operation on a truck with under 1000 miles? I'm taking it in to the dealer tomorrow and want a tech to ride along with a star scan tool hooked up. I'll post what he says.
jlb
MT
CTD
Not really sure lol, this is the first truck I have ever had an automatic in, and I despise it so much I just put it in gear, and try to ignore the fact I don't get to shift...
M
mrtosh
Lol I know what you mean. Soo much computer controlled TCC lockup and torque management these days. Makes a 400hp hemi feel like a 4cyl Mazda.
Hollabakzach23
Lafayette, IN
Mine does the same thing in second gear only drops about 500 rpms but when i fully accelerate it gets on it just fine. I have a 98 though so not near as new. I have been told its just the torque converter and it's nothing to worry about though so idk.
Ramunit
Normal tc lockup.
Lawhand
Baton Rouge, LA
this is due to the new "6 speed" trans... 2nd and 3rd gear have only about a .2 ratio diff. so this means ushift between 2nd and 3rd gear but its not like going from 1st to 2nd or 3rd to 4th. I noticed mine would sometimes increase by 10mph without the engine turning over anymore than 2500 rpm. This is due to the gear change and close ratios. atleast this is what i believe the be the cause
garner
Harker Heights, TX
^Yupp! The 2012 use 2nd prime as an actual driving gear so the rpm drop very little when it shifts from 2nd to 2nd prime
jlb
MT
CTD
In the previously tuned version, up to 2011 2nd prime was a downshift only gear for passing. I.e. the truck would never use it when it was counting up from a stop, only on the highway when you tromp on it to pass or something. It has a slightly better ratio for top end speed than 2nd.
garner
Harker Heights, TX
What's 2nd prime mean?
It's a gear between 2nd and 3rd used to reduce the dramatic difference between 2nd and 3rd gear. In 03-11 it was only available for passing on the highway or manually shifting. But in the 2012 it is used all the time
Lawhand
Baton Rouge, LA
yeah sometimes it makes me angry. my truck doesnt like 25MPH speed limits in my hood. makes weird groans in 2nd prime at 25 MPH. (mufflex exhaust sounds)
Ramunit
Just for the record 2nd prime started being used as a regular upshift starting in 06 so 03-05 highway kickdown only, 06-12+ regular upshift and downshifts but that is neither here nor there.
Avurado
