3.21 to 3.92
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
I have 3.21 in my '14 Sport but am thinking of going to the 3.92 and putting a lift and 35s on it. It is 4wd. Talked to service manager at a local dealer and he quoted $262 for rear parts and $1493 for parts on front diff. My question is would i need to have the speedo recalibrated if all i did for now was change the diffs? Or could that wait until the bigger tires were installed?
matt.davidson09
Texas
2013 RAM 2500 Laramie Mega Cab
6.7L Cummins
Following as I eventually want to do the same with 37s. $262 seems cheap for regearing the rear?
shane1981
millington tn
you wont need it calibrated just for the gears. the speed sensors are behind the rotor so they read wheel speed
tuned by Jay Greene
bryan28
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
Well i just heard back from them and they said it'd be a low estimate of $3900 for everything installed but that they're not sure it'd work up front. Something about the transfer case being designed to work with what originally came in the truck (3.21s). And that it may be a couple more grand if they had to do something to make it work. I know nothing about this stuff but i'm calling bs! But since they seem incompetent i will not be letting them do it.
Sickem
2017 1500-Express 3.92's w/ anti-spin
Lol. That's ridiculous and don't even make sense that the transfer case would be impacted by going to lower gears.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
It wont be, seems real high to me, search on here someone did this not to long ago and the parts were less then you would think.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
I think that Moe's Performance(a vendor on this site)has the parts you need. I believe his prices are much cheaper than a dealer.
Jay
Trexterra
That's about the price 4wheelparts did mine for in my 14. Dealer paid 3200 and I only paid 800 though.
RLJ10X
Southern Indiana
35"/3.92/8 speed would probably be ok. I don' know whitch trammy you uys have......
If it was me, and l was going with 37 inch tires, l would research 4.10s real hard. Maybe even 4.56s. Talk to Matt at Moe's. He will steer you in the right direction.
I have 32"/33" stockish tires with 4.10s, and the 545RFE, just a CAI, and a tune. My truck moves out very well for a nearly stock, 5600 pound truck.
bryan28
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
Well my local dealer who I bought the truck from won't even touch that job. They also said it would void the warranty. It's a 14 so has 12 months left on the 3 yr bumper-bumper and 3 years left of the 5yr/100k mile powertrain warranty. So I'm either gonna hold on to what I have or buy a new one equipped the way I want.
crash68
ACME product engineer
Administrator
3.0 EcoDiesel
That dealer is so full of crap they would plug a toilet.
Sounds more like they don't have any techs skilled enough to do the swap.
Find another dealer or a good drive train shop. Only thing could "voided" on the warranty would be the axles and how often do they go bad.
fasthemiram12
Eagle 5.7 vvt
You can't just put gears in your front housing... you have to swap to a 3.92 front ifs assembly. They are not serviceable 2012+
jonathanhudaon
There's got to be some way around this. I want to change the gear in my 13 but have stayed away because of the cost associated with a full front swap. Someone must know another that's not so costly
Trexterra
You could try and find a used stock 3.92 front end and matching rear. That's the only current "cheap" method. Iirc 4.10s weren't even an option due to the front diff. I could be wrong though.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
The front diff is not that much money a guy posted what it cost a month ago or so.
swap out the front diff and change the gears in the rear.
