4.56 or 4.10?
maxgarton
Hey,
So I have a 2013 1500 with 3.55 gears but I also have 37" tires. At the moment the truck is super slow (still beat an ecoboost In a 1/8 mile though).
To change the sluggishness I definitely want to do a gear change. I'm either thinking 4.10 or 4.56 gears. I did the math and to return to stock feeling the math says 4.23 gears (which I can't find). I'm leaning toward 4.56 but I know I will have to shave the casing. Wanted to know your thoughts before I did anything.
Thanks
Juvenator93
4.56 definitely. But like stated above, big costs coming your way [emoji28]
Jimmy68
Lethbridge Alberta Canada
5.2L Magnum
4:56 to get performance back. May be lower but that is a good thing as the tires are larger, therefore heavier and take more to get moving.
M
maxgarton
Looks like I'll go with 4.56, also I heard some people talking about a different clip or something else that has to be different to hold the ring on. I know the case needs to be shaved but is there something else that has to be done to be able to hold a 4.56?
Thanks
Burla
2010 Hemi Reg Cab 4x4
Part of the expense will be the gas you burn on the freeway. You have the 8 speed? I have the 3.55 and I feel ya, they suck the bone. Driving my friends 3.92 makes all the difference. Spins the tires w/o thinking about it.
charonblk07
Calgary, Ab
F1-A forged 349ci
Hey,
Thanks
Ok, just want to be sure you're prepared for the expenses as this isn't as simple as it's been in past years. Do you have the 6-speed or the 8-speed? You do know that you'll have to completely swap the front diff to a pre-'11 diff so you can change the front gears and nobody makes an adapter bracket so it'll bolt up, it's something you'll need to make to work.
I've never been a fan of US Standard gears, the Motive or Yukon gears have always broken in better and with less material shedding/chipping even with professional installation, it's a different metallurgy and treatment IIRC.
M
maxgarton
I see you mentioned front diff in your response, I failed to mention previously it's a 2wd truck (wish I had 4wd) but I guess it'll save me a bunch of money. It's also a 6 speed.
I do plan to do the installation myself but I don't want a mistake of mine to cost me more than just taking it somewhere in the first place. I'll definitely be able to do the backlash measurement but I'm only worried about the depth at which the pinion sets.
Think I'll be able to pull it off on my own?
huntergreen
i would go with yukon if avail. for me , i would 4:10 and be happy.
charonblk07
Calgary, Ab
F1-A forged 349ci
If it's only a 2wd then it's really straightforward and since you have the 6 speed you definitely want the 4.56s.
yillbs
A wise man said on the "z" forum
The rear end is only half the equation, final drive ratio which includes transmission gearing is what matters. If you have a lower gear ratio then you'll take off quicker but you will top out at a lower top speed. Rams are limited to 105 MPH anyway, but you can remove the limiter with a tuner. IMHO 4.88s with an 8 speed are unnecessarily low and will give you a 22.98:1 1st gear final drive ratio-you will probably shift out of 1st by the time you hit 3 MPH. If you have 3.92s i wouldn't waste money going any lower.
Many people are not used to newer transmissions that have a lot of gears and allow for a wider range. Back in the day when they had 3 or 4 speed transmissions you needed 5.88s to get a load moving with a tall 1st gear in the transmission, but that also limited your top speed. By gearing with the transmission you have a similar top gear (8th and 6th gear for the 8HP70 and 65RFE respectively are both 0.67:1), but a lower first gear (4.71:1 in the 8 speed vs 3.00:1 in the 6 speed).
If you had a 6 speed with the same final drive ratio in 1st gear that the 8 speed provides then your diff gears would be:
3.21 (8 speed): 5.03 (6 speed) differential
3.55 (8 speed): 5.57 (6 speed) differential
3.92 (8 speed): 6.15 (6 speed) differential
conversely, an 8 speed would have to have the following diff gears to provide a similar final drive ratio to the 6 speed:
3.21 (6 speed): 2.044 (8 speed)
3.55 (6 speed): 2.26 (8 speed)
3.92 (6 speed): 2.50 (8 speed)
Actual 1st gear final drive ratios for a given differential/transmission combo:
3.21/6: 9.63:1
3.21/8: 15.12:1
3.55/6: 10.65:1
3.55/8: 16.72:1
3.92/6: 11.76:1
3.92/8: 18.46:1
4.10/6: 12.30:1
4.10/8 (never offered, but demonstrative): 19.311:1
When have 5.03s ever been a necessary gear in a 1/2 ton? You can only get so far before you end up with such low gearing that the truck shifts to 2nd at 2mph or so. How useful is that gear?
Once you are moving and out of 1st gear it doesn't make much difference anyway as a truck with taller diff gears can drop a trans gear to accommodate. FWIW the trans gears for the 6 and 8 are, respectively:
1st 3.00:1
2nd 1.67:1
3rd 1.50:1
4th 1.00:1
5th 0.75:1
6th 0.67:1
Reverse 3.00:1
1st 4.71:1
2nd 3.14:1
3rd 2.10:1
4th 1.67:1
5th 1.29:1
6th 1.001:1
7th 0.84:1
8th 0.67:1
Reverse 3.30:1
Now compare this to Toyota, which I will use as an example because they offer only 4.10 or 4.30 gears in the Tundra which are very low. This is because their transmission gearing is so tall. With the 4.30 diff in a Tundra and their 3.33:1 1st gear you get a 1st gear final drive of 14.319:1
A Ram with the 8 speed and 3.21s has a first gear final drive of 15.12:1 as I said before.
That means if you have an 8 speed Ram with 3.21s it is actually geared lower than a Tundra with 4.30s.
Another thing, if you are going super low your ring gear will need to be larger or you will risk breaking it, which is one reason Toyota uses a 10.5" ring gear (and you can find accounts of theirs braking more than infrequently). We have 9.25" ring gears, so lower than 4.10 I would be concerned. I don;t know if a 4.56 or lower will actually fit.
