What happened to the engine?
A short block from anything '09+ will work. If you just want to direct swap the engine then get a '09-'12 but if you can reuse all your accessories and intake manifold then you can get any short block from '09 and up from a 1500.
Dealership says the mds is different. 10-12 but everything else the same so that's what's holding me up. I'd rather buy a good used motor with low miles. I've never messed around with the insides on a 5.7
The MDS system is the same, my forged block came from a '11 and everything swapped over from my '09 and worked before I totally deleted it when I put the bigger blower on it. They didn't make 1 year of the new vvt block, it changed in '09 and has been the same since except for programming and external accessories.
