Hi guys I am new to the forum. I am looking at a 2015 1500 Longhorn with the 5.7. I had a 2008 Chevy with the 5.3 and it used oil like it was made by the Saudis. I know a LOT of the Chevys have this problem doe to the cylinder deactivation. My question is about the Rams. Do they have problems like the Chevys due to deactivation cylinders? I am tired of hearing a quart of oil every 1000 miles is normal. I really like the Ram but once burned....
By the way the engine let go at 130,000 and I had to get a re-man engine then it was wrecked. Scared of GM.
Below is an excerpt from FCA TSB 09-007-15 concerning oil consumption.
NUMBER: 09-007-15
GROUP: Engine
DATE: July 31, 2015
THIS BULLETIN SUPERSEDES SERVICE BULLETIN 09-001-12, DATED JUNE 27,
2012, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE
HIGHLIGHTED WITH **ASTERISKS** AND INCLUDES UPDATES TO MODELS AND
OIL CONSUMPTION.
SUBJECT:
Engine Oil Consumption Guideline
**MODELS:
This bulletin applies to all 2012-2016 FCA US LLC vehicles equipped
with gasoline engines.**
DISCUSSION:
Engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the power stroke, part of this oil layer is consumed in the combustion process. Varying rates of oil consumption are accepted as normal in all engines.
Oil Consumption
**The accepted rate of oil consumption for engines used in the vehicles listed above is 1 quart (0.946 liter) in 2,000 miles (3,200 km) for the 1st 50,000 miles (80,467 km). For vehicles with more then 50,000 miles (80,467 km) the acceptable oil consumption for engines is 1 quart (0.946 liter) in 750 miles (1,207 km).**
CAUTION : This above rate only applies to personal use vehicles, under warranty, that are driven in a non-aggressive manner and maintained in accordance with the appropriate maintenance schedule.
