Technically they're good to 100k. If you're planning on keeping the truck, I would pull them out, check the gap, put antiseize on the threads, dielectric on the coil boots and reinstall.So my 2014 is at 50k miles. When should I change the plugs as I've read they are different.
Ha very trueIf you go through all of this trouble, put new ones in! This is kind of a pain in the ass job to do.
The guy at autozone said that he recommends changing the lower plugs at 50k miles and uppers at 100k on the hemi. He said that the lowers receive more pressure from combustion.
Is that actually a thing or was he making a sales pitch?
If a plug located in different spot in the combustion chamber is receiving more wear than another then you have a different problem. Cylinder head and piston top design along with ignition timing events are specifically worked in an attempt to make VERY even cylinder pressures. Pre- detonation and poor combustion chamber efficiency lead to uneven chamber pressures. Uneven cylinder pressures actually lead to premature cylinder wall wear from the piston failing to maintain perfect center in the cylinder. This is quite common in "less than perfect" high performance engines and engines using very short skirted pistons.The guy at autozone said that he recommends changing the lower plugs at 50k miles and uppers at 100k on the hemi. He said that the lowers receive more pressure from combustion.
Ok good. All my old plugs looked relatively the same.If a plug located in different spot in the combustion chamber is receiving more wear than another then you have a different problem. Cylinder head and piston top design along with ignition timing events are specifically worked in an attempt to make VERY even cylinder pressures. Pre- detonation and poor combustion chamber efficiency lead to uneven chamber pressures. Uneven cylinder pressures actually lead to premature cylinder wall wear from the piston failing to maintain perfect center in the cylinder. This is quite common in "less than perfect" high performance engines and engines using very short skirted pistons.
Long story short, no this should not be the case.
Those are good plugs, just not for a 2013 and older Hemi. They require very specific plugs with very specific heat range and conductivity. If it were me I'd return those and order the NGK Mopar ones from Amazon like Burla mentioned.Mine is a 13....figures. Mechanic shop said they were good ones but they aren’t total Ram guys like you guys so just wondering. Made an appt for Thursday so won’t have time for Amazon. Have to take a drive and check other shops inventory. Those Champion Iridium junk? They were 5 bucks a plug so I thought I did good by not buying cheap ones...
Fyi they changed these in 2013.. not sure if it was mid production but my buddies 2013 is the 100k plug setup for the 5.7Mine is a 13....figures. Mechanic shop said they were good ones but they aren’t total Ram guys like you guys so just wondering. Made an appt for Thursday so won’t have time for Amazon. Have to take a drive and check other shops inventory. Those Champion Iridium junk? They were 5 bucks a plug so I thought I did good by not buying cheap ones...
How can I tell which plugs I have? Mine is very late '13 with the 8 spd.
