Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Engine & Performance
65rfe 4th gen 6 speed auto xsmn .
This is a discussion on 65rfe 4th gen 6 speed auto xsmn . within the Engine & Performance forums, part of the 4th Gen : 2009 - Present category!
Hello ALL . I'd like to start a thread discussion about the 6 speed XSMN 65RFE to help all of ...
Like Tree335Likes
Sponsored By: Moe's Performance
Reply
Old 08-18-2016, 06:58 AM   #1 (permalink)
R.L.K.'s Avatar
Ram Year: 2014 4X4 QC Express 6 speed auto 355 differentials
Engine: 5.7 Hemi
Default 65rfe 4th gen 6 speed auto xsmn .
Hello ALL .
I'd like to start a thread discussion about the 6 speed XSMN 65RFE to help all of us out in understanding as much as possible about this xsmn and different maintenance practices like fluid & filter changes and other info like normal operating temp ranges , gearing , shifting points , common NON-preventative maintenance , similarities to the 45 RFE , 66RFE & 65RFE XSMN's and such.
My truck 2014 Ram 1500 QC 4X4 5.7L Hemi, 65RFE 6 speed automatic xsmn with the -45 Xsfer case , 3.55 Differentials , Razorback Red with the 6'4" bed , leveled with Bilstien @ + 2.8" with 1.5" TGC rear coil sping spacers , OCC and stock tires & chrome clad wheels . Wow that's a mouthful!
I'm at about 44k and I'm interested in a XSMN fluid & filter change , and possibly a DIY complete system Flush .
Also interested in a xsmn pan change with extra fluid capacity , cooling fins and a magnetic drain plug.
I'm gonna save a few spots below for my fluid & filter change and other maint related stuff I plan to do in the future on my 65RFE automatic xsmn.
Thanks in advance for your replies !
Sponsored Ad
Register to remove this ad.
R.L.K. is offline   Reply With Quote
Old 08-18-2016, 06:59 AM   #2 (permalink)
R.L.K.'s Avatar
Engine: 5.7 Hemi
Default
I just purchased (12-28-2016 ) a MAG-HYTEC 45RFE XSMN Pan today .
This pan has many featurs that the OEM pan does not.
1) First and for most it has a Drain Plug !
I Do Not understand why a drain plug is not standard ?
This drain plug has a very strong Magnet on it , so when you drain the fluid you can clean the captured ferrous debris , what a great idea !
2) This pan has a +1.5 to +2 Qt. Capacity of fluid over the OEM pan , this extra capacity aids in the cooling of the xsmn , this is great for people who tow , especially in the summer .
3) Speaking of cooling the xsmn, this pan also has a large amount of Cooling Fins , now that's just a good idea !
4) The wall thickness and the Mounting Flanges are much thicker than the OEM pan , this is great for you 4 wheeling enthusiasts & Rock climbers , also Aids in disipating HEAT as well !
5) Lastly this pan just looks cool 😆 pun intended! Get it ? Looks cool and it has many fluid cooling characteristics 😎 anyway here's a picture .
Notice the giant step in the pan , this is to clear your stock exhaust system . If you have a non oem exhaust that doesn't interfere with this area then for a +2 more qt fluid capacity you can install the 68RFE DEEP Pan that looks like this .
Hemi395 likes this.
Old 08-18-2016, 06:59 AM   #3 (permalink)
R.L.K.'s Avatar
Engine: 5.7 Hemi
Default
Saved for later use .
Old 08-18-2016, 07:00 AM   #4 (permalink)
R.L.K.'s Avatar
Engine: 5.7 Hemi
Default
Saved for later .
Old 08-18-2016, 07:00 AM   #5 (permalink)
R.L.K.'s Avatar
Engine: 5.7 Hemi
Default
Saved for later.
Old 08-18-2016, 08:22 AM   #6 (permalink)
Hemi395's Avatar
Ram Year: 2013
Engine: Hemi 5.7
Default
I recently changed the fluid and filters in my 6 speed. If you've done any other transmission fluid changes on older GM or Ford transmissions it's very similar. Only difference is there's two filters, one is a typical screen type filter and the other is a spin on oil filter type filter. Originally I was using the Dorman replacement pan for the 66&68rfe trans but have found some info on it that it may be pushing slightly sideways on the pump filter so this weekend I will be adding a B&M drain plug to the OEM pan and reinstalling that. I'll take pics of the process and post.
Originally I was going to refill the fluid with Redline C+ but after reading up on ATF+4, it seems these transmissions are very sensitive to the type of fluid used so I would highly recommend using one of the certified/licenced ATF+4 listed here http://www.centerforqa.com/chrysler-brands/
I used Castrol TransMax as it was available locally and has good reviews.
R.L.K. likes this.
__________________
Black 2013 Bighorn Crew Cab Hemi 65RFE 3.55s 4x4
PUP 3qts SRT 0w40 & 4qts 5w30, Redline C+, Redline Gear Oil, Diablo Trinity w/Hemifever 93 Tune, BT Catch Can, Mufflex 24, Rancho QLL, Cooper Discoverer AT3s, Mag-Hytec Trans Pan, OEM Backup Camera, Kicker Speaker Upgrade, Extang Trifecta SS, Clazzio Seat Covers, Cabin Air Filter, Weathertech Floorliners, 35% tint, Gorilla Lugs, Nasta Stainless Running Boards
Hemi395 is online now   Reply With Quote
Old 08-18-2016, 09:44 AM   #7 (permalink)
nickpohlaandp's Avatar
Ram Year: 2014
Engine: 5.7 Hemi
Default
Not that it has ANYTHING to do with anything, but we use Castrol Transmax Z in all of our helicopter gearboxes and transmissions.
gillt1 and Hemi395 like this.
nickpohlaandp is offline   Reply With Quote
Old 08-18-2016, 10:52 AM   #8 (permalink)
U&A's Avatar
U&A
Ram Year: 2016 3500 SRW
Engine: 6.4 HEMI
Default
Im assuming im allowed to play in this thread, owning a 66rfe. same thing, but different
I will be using the castrol atf+4 as well. still up for debate on the pan I will be using.
R.L.K. likes this.
__________________
2016 RAM 3500 SRW, tradesman, 6.4 HEMI, CC Long bed, 4x4, 3.73 gears/anti spin, HD front axle (SPP), Rhino liner, TruXedo Lo Pro QT, EGR Black Matte Inchannel Window Deflectors, EGR Black Matte Superguard Bug Shield, Weigh-Safe (2.5") 8" drop, TOYO M/T 285/75/18 (35.1x11.6x18)
Amsoil SS 0W40, Fram Ultra Synthetic, TCW3/MMO in gas
U&A is offline   Reply With Quote
Old 08-18-2016, 12:44 PM   #9 (permalink)
R.L.K.'s Avatar
Engine: 5.7 Hemi
Default
You are welcome here as well my friend LOL ! similar xsmn just the 2500 right ?
Old 08-18-2016, 12:47 PM   #10 (permalink)
U&A's Avatar
U&A
Engine: 6.4 HEMI
Default
3500 with the 66rfe. basically the same as yours. with a twist.
https://en.wikipedia.org/wiki/Chrysler_RFE_transmission
R.L.K. and fordtech90 like this.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Low Fan Speed Auto Climate Setting QwikKota Engine & Performance 2 12-11-2015 10:26 AM
8 speed auto transmission oldbobbyd Site Comments, suggestions, and questions. 3 05-07-2015 05:43 PM
8 speed auto park talk2cpu General Discussions 18 01-06-2015 02:06 PM
Why so many 6 speed auto's at the dealer? Burla General Discussions 20 10-08-2014 02:55 PM
6 speed auto shifting characteristics SmokeycoonhoundUT Engine & Performance 1 04-10-2014 09:32 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
