Aftermarket panties on.
Did you guys fully tighten the bolts right when you put the pan on or did you just snug them and let the RTV cure before you tighten them down fully ?
I've always snuged down evenly initially & waited an hour or two then torqued to specs then add fluid , start it up cycle through the gears a few times set the E brake & put into Nutral check & adjutant the fluid .....
Drive it to get temps up , reverify fluid level ( adjust accordingly ) then after the xsmn pan has cooled to outside air temp I tq check all the pan bolts .
Not saying this is the best way , just the way I've done it for years and I've never had any leaks or issues .
Hope this helps and how bout some pics of the pan .
Did you get the sump filter seal replaced ?
