65rfe 4th gen 6 speed auto xsmn .
R.L.K.
R.L.K.
Bristol , Tn.
Some folks do an entire flush by removing the hose and pouring in fresh fluid while in drive , E brake on and wheels chalked ( or someone else at the wheel ) until fresh clean fluid comes out . This is not a bad idea , but me personally ...I have the Mag-Hyteck with a drain plug , I just pan drain approx 8.5qts for me drive about a thousand miles then pan drain again . This method works for me .
Hope this helps!
Reactions: U&A
Hemi395
Cape Cod MA
I use this same method and it works great. It's also a lot easier than messing around with the cooler lines and there's no chance of creating a leak at the cooler line connections
Luis
HEMI 5.7
Great write up and lots of information on here from multiple people, its interesting seeing the different methods used.
I do have 2 question, how do I identify which 6 speed transmission I have? Also is one better than the other?
R.L.K.
R.L.K.
Bristol , Tn.
@Luis ,
What year is your Ram ?
To my knowledge all 2013- 2018 1500 6 speed xsmn's are all the 65RFE .
I'm thinking your wanting to know which 4x4 transferase case you have ?
If so then it's marked on the xsfer case as either the BW 44-44 or the 44-45 on a bar code sticker , also on your 4x4 shifter dial they have different settings .
I think the 44-44 has the 4wd- auto position and the 44-45 ( the good one Imo ) does not .
Let us know here what positions are on your 4x4 selector dial .
Hope this helps .
R.L.K.
R.L.K.
Bristol , Tn.
For anyone interested in some really good in-depth information to include quick learn info check out Rampants post # 85 & 86 here , I've tried to relocate his post to the end of my OP BUT for some season I can't edit my OP
TO MODS can one of you guys relocate Rampant's post #s 85&86 to the end of my OP ? Thanks R.L.K.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
The other 6-speed transmission is the 68RFE for the Ram 2500/3500
R.L.K.
R.L.K.
Bristol , Tn.
Yep , I stated "1500" .
This latest Forum format on Tapatalk doesn't show truck year , type or eng type anymore ?? Frustrating because you can't look at someone's profile to see what they are driving ...I hope this is a glitch and not intentionally modified . If it was intentional then it was done by someone who doesn't spend any time on the Ram Forum...
Hemi395
Cape Cod MA
Yeah editing older posts isn't working on both Tapatalk or a PC. I messaged Smiley about it and he's looking into it.
R.L.K.
R.L.K.
Bristol , Tn.
Good deal , I have a few older DIY threads that I update /add to on a regular basis so they are up to date with the latest info available and such .... Hope SMILEY GETS THIS FIXED ....
Maybe I'll PM Smiley as well ....OH THATS RIGHT I CANT PM ANYMORE ITHER ..ERRR THIS SUCKS SO BAD !!!!
Luis
HEMI 5.7
@Luis ,
Hope this helps .
I have a 2011 Laramie
R.L.K.
R.L.K.
Bristol , Tn.
Then I believe you have the 5 speed 545RFE if you have a 1500.
Luis
HEMI 5.7
Trying to learn as much as possible about my Ram, is it not a 4th Gen 6 speed?
R.L.K.
R.L.K.
Bristol , Tn.
@Luis ,
2009 + Rams are considered 4th Generation ;however , they do not all have the same xsmn's ...
I believe your 2011 1500 would have the 5 speed 545RFE xsmn ...
I suggest getting your build sheet from the above link provided by crackerjack , this will list all OEM items as the truck left the factory , if I remember correctly you can request a paper copy to be sent to you .
R.L.K.
R.L.K.
Bristol , Tn.
Link doesn't work for me
R.L.K.
R.L.K.
Bristol , Tn.
This is all I get when trying to open the link
