I just upgraded the valve body on my 2013 with the Transgo Reprogramming Kit. This kit is made to address a few of the weaknesses with this transmission. I installed the upgraded springs, new seals and cover plate on the valve body. I am very happy with this mod. The trans now shifts much faster.
The kit also includes a stronger spring for the pump to increase and hold higher line pressures. Also, a stronger snap ring (which is what took out my first trans).
** I am looking for someone in the NJ, DE, PA are to install the pump spring and snap ring** Anyone looking for a fun job send me a message.
Transgo does not have the 65rfe listed on this kit but when I called they assured me it would work and it did.
FYI the kit also includes a resister to increase line pressure (like sonnax plug) but do not use with a tuner. There was one other part that comes in the kit that is for the older trans, so I just tossed it out.
Looks like the spring that comes with the sonnax is for the pump, so if you want to install it you will need to pull the trans and crack open the pump. A mod that is a little above my wrenching abilities.
