magic280z
- Dec 30, 2016
- 111
- 44
- 2019 1500 Laramie
- Hemi 5.7
There are some definite opinions on here about 3.92 gears. Having just purchased a 3.21 Hemi 8spd truck they would have you feel that the truck can't really do anything and is nothing more than an oversized suv. Now most of us may use our trucks for that doesn't mean they can't also be a truck.
I decided to compare the final drive ratios of both setups and found out some interesting info.
8-spd (8hp70) 3.21
1- 15.09
2- 10.05
3- 6.74
4- 5.36
5- 4.14
6- 3.21
7- 2.7
8- 2.15
6-spd (65rfe) 3.92
1- 11.76
2- 6.55
3- 5.88
4- 3.92
5- 2.94
6- 2.63
Looks like the 8spd 3.21 still has the edge over the 6spd 3.92. I know everyone knew the 8 was better than the 6 all else being the same, but this shows how much different the 8spd is. Basically the 8 spd 2-7 is the 6 spd 1-6. You gain a whole lot better first and pretty decent 8th. And the 6 spd really is just a 5spd during linear upshifting. 3rd gear is an optional kickdown gear or it can be used when electronically shifting, but is probably useless being so close to 2nd.
So if you are upgrading from a 6 spd 3.92 truck you should feel comfortable going with the 3.21 gearing you will have better acceleration and fuel economy. If you just want the fastest possible acceleration or need to tow 10,000 lbs then feel free to go 3.92 with the 8spd or go find an r/t with a 4.10 (not sure if 8spd or 6spd).
I added the 3.92 just to have the info.
8-spd (8hp70) 3.92
1- 18.42
2- 12.27
3- 8.23
4- 6.55
5- 5.06
6- 3.92
7- 3.29
8- 2.63
8-spd (8hp70) 3.21
1- 15.09
2- 10.05
3- 6.74
4- 5.36
5- 4.14
6- 3.21
7- 2.7
8- 2.15
6-spd (65rfe) 3.92
1- 11.76
2- 6.55
3- 5.88
4- 3.92
5- 2.94
6- 2.63
8-spd (8hp70) 3.92
1- 18.42
2- 12.27
3- 8.23
4- 6.55
5- 5.06
6- 3.92
7- 3.29
8- 2.63
