Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Engine & Performance
8 Speed 8PH70 Question
This is a discussion on 8 Speed 8PH70 Question within the Engine & Performance forums, part of the 4th Gen : 2009 - Present category!
I am curious for those who own the 8 Speed. After initial break in-->How many have actually drained the pan ...
Like Tree51Likes
Sponsored By: Moe's Performance
Reply
Old 05-16-2014, 10:05 PM   #1 (permalink)
SyN's Avatar
SyN
Ram Year: 2014
Engine: 5.7L
Default 8 Speed 8PH70 Question
After initial break in-->How many have actually drained the pan and added fresh fluid?
I assume within the plastic black finned pan that some what drain plug looking item is actually a drain plug for the 8PH70?
If any of you have actually drained this pan-->How many quarts actually drain out from the pan?
I have plans on doing this around the 10K mile mark.
Yes I know this does not actually drain {ALL} the fluid from the transmission.
I am just curious how many quarts actually drain from the pan itself.
Thanks
Sponsored Ad
Register to remove this ad.
__________________
2014 Bighorn SLT 1500 QC 4WD 5.7L BW44-44 8HP70 3:92s w/Anti-Slip!
Oil: 6Qts (GTL) PUP 5W-30 / 1Qt (GTL) SRT 0W-40 & 4oz ZDDP Plus w/RP Filter!
Front -8HP70/T Case- Rear: RL 75W-90 - Red Line D6 ATF - RL 75W-140/90 Mix!
Coolant: Peak Global Lifetime w/RMI-25 Air: AEM Drop In {Dry-Flow}! No CAI!
Fuel: (Shell) 89 w/6oz TCW3 or 24oz Soy Ultra / Neutra! Mileage: 24,429
SyN is offline   Reply With Quote
Old 05-16-2014, 10:26 PM   #2 (permalink)
KTM's Avatar
KTM
Ram Year: 2014
Engine: 6.4 Hemi
Default
From what I have read on this Forum, there isn't even a dip stick to check the Tranny fluid, this worries me since i have also read that some of these new trucks were shipped out a few quarts low????? YIKES!!!!! Makes me want to drop the pan drain the the fluid and fill it up on the dealers lot before i drive it off. My truck isn't even built yet and I'm already worried about it. LOL
Hopefully there will be some good input for you about this topic, I am obviously no help.
__________________
2014 2500 Bighorn CC, 4X4
KTM is offline   Reply With Quote
Old 05-16-2014, 10:31 PM   #3 (permalink)
SyN's Avatar
SyN
Ram Year: 2014
Engine: 5.7L
Default
Unholy PooP! I never even thought about looking for the transmission dipstick! Ah this is gonna suck.
I hope this is not like my daughters Audi.... Only the dealership can actually service the Automatic Transmission. Car has to be on a lift and fluid has to be at a certain Temp to change it.
__________________
Old 05-16-2014, 10:36 PM   #4 (permalink)
KTM's Avatar
KTM
Ram Year: 2014
Engine: 6.4 Hemi
Default
Well I have heard more good than bad about these new tranny's, so we might just be worrying about a problem we don't have. It will be interesting to see if someone post a reply about draining one. BTW, any photos of your new rig? Sounds like we have very similar trucks, with one exception. YOU ALREADY HAVE YOURS.
__________________
Old 05-16-2014, 10:53 PM   #5 (permalink)
SyN's Avatar
SyN
Ram Year: 2014
Engine: 5.7L
Default
Had my truck for 2 weeks. Been working so much have not had time to give her a nice warm bath and fresh coat of wax. Once that is done a few pics will be up.
I hope this is not a wanna be life time fluid. I can't find any info in the owners manual about the service interval of the 8speed. Just the fluid type. I have only had 4 hours sleep and my eyes are so tired.
I hope other owners who know more about this transmission and have honest truthful facts can shine alot of light here.
Did a bit of research on this New Transmission! I am now so glad I bought the Ram with the 8 Speed.
I will do my first service around 25K-30K. Gives me more research time!!
Very impressive Transmission!
After more research--->I love the pedigree of this Transmission.
It is a lifetime ZF Lifeguard Fluid Fill--->Which I don't like!
Now to find out the {Correct} way to change this expensive fluid. I'm not a believer in these Fill and Forget it Fluids.
Moparman1303 likes this.
__________________
Old 05-17-2014, 11:32 AM   #6 (permalink)
SyN's Avatar
SyN
Ram Year: 2014
Engine: 5.7L
Default
Looks like the Plastic Pan and Filter are 1 Unit. OUCH! $$$$
Sounds like--> Severe Service=35K - 40K Miles Normal Service=60K miles
No other way around it-->If you have plans on keeping this auto for many years to come. Your going to have to spend some $$ to service this transmission--->If you are anal about things you spend a lot of your hard earned $$$ on.
If Not? Just drive it until it quits and leaves you stranded.
__________________
Old 05-18-2014, 07:02 PM   #7 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
You do not change the oil in 8spd. It is a sealed unit. Only time oil is changed if the tranny is rebuilt or worked on.
THETANK and Schu3507 like this.
__________________
Thanks
Bighorn14
BigHorn14 is offline   Reply With Quote
Old 05-18-2014, 07:48 PM   #8 (permalink)
lonewolf2873's Avatar
Ram Year: 2014 Ram Crew Cab 4x4
Engine: Hemi 5.7
Default
You do know their is 2 different 8speeds right??
Just checking to see if your worrying about nothing.
__________________
BT Polished Catch can, Mufflex Muffler delete, AVS Vent visors, 180 Tstat, Hellwig rear sway, Truxedo Tonneau, Deezee tailgate shock, Amsoil Air filter, Amsoil Synthetic 5w20, Bilstein 5100 front 2.8, Bilstein rear + 1" spacer, Zone UCA's, Hemi fever Tuned Diablosport.
lonewolf2873 is offline   Reply With Quote
Old 05-18-2014, 08:50 PM   #9 (permalink)
Moparman1303's Avatar
Ram Year: 2014
Engine: Hemi 5.7L + 8spd
Default
How much to service the tranny? What is the service interval to follow?
Sent from my LG-D803 using Tapatalk
__________________
2014 Ram 1500 Outdoorsman Quadcab Hemi w/3.92
Moparman1303 is offline   Reply With Quote
Old 05-18-2014, 09:53 PM   #10 (permalink)
SyN's Avatar
SyN
Ram Year: 2014
Engine: 5.7L
Default
Lonewolf: My Ram come with the 8HP70! I'm not worried about any other.
I know I am worrying about really nothing right now. My 8 Speed only has 485 miles on her. I'm sure by the time I reach 50K miles, I will have come across accurate information on the correct way to service and time of service on this transmssion.
I do know the ZF fluid is NOT CHEAP! & The Plastic Pan and Filter are 1 unit!
Moparman: If I ever come across that information! I will share with you! Please do the same with me!
I keep hearing and seeing it is a Life Time Fill! Ya never have to service it until it blows up on you.! I will never let this happen If I can prevent it.
Like I said-->I'm worrying about something that I really don't have to worry about until the 40K-50K mile mark.
I'm one who always likes to be prepared for the Unexpected! I only hope this is a service I can do in the drive way... I don't like being Butt Raped by the Dealer and charged $800 for a job I can do for $300.
Rick Bobby likes this.
__________________
Reply
Bookmarks
Tags
ram 8-speed tranny
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
8 speed question....since it's 100% electronic in cab... mesaboogie General Discussions 10 01-29-2014 02:55 PM
8 speed transmission usage question kenwitter Engine & Performance 3 09-10-2013 06:12 PM
Question About The New 8 Speed Automatic Transmission!! KSA RAM Engine & Performance 7 02-18-2013 04:10 PM
Question for V6 8-speed owners homeyclaus General Discussions 17 02-04-2013 09:43 PM
5 speed automatic trans question tdekubber Engine & Performance 6 02-12-2011 02:55 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
