- May 11, 2016
- 219
- 338
- North Carolina
- 2017
- 5.7 Hemi
The transmission heater has come up on several threads over the past few months, particularly by those who feel the 185 degree and higher transmission temperatures are too high. I'm one of them. Without gaining inside engineering data from FCA, it unfortunately will not be possible to find out what the quantifiable efficiency gains FCA realized by heating the transmission fluid, and keeping it hot, versus letting the trans cooler do its job and dropping temperatures to the 150 - 160 range (the range the transmission in my 2011 3500 Cummins saw all the time).
Anyway, I managed to acquire the transmission heater assembly ( Mopar P/N 52014750AD), and started to examine it's operation. The thermal bypass valve (TBV) is located on the lower left side of the assembly (right above the lower mounting bolt), and is held in place by a retaining ring. Two o-ringed tubes provide for ATF flow into and out of the heater. ATF from the trans enters the heater via the lower tube, is simultaneously heated by engine coolant, and also is routed out to the ATF cooler. The TBV lets heated ATF flow back into the trans via the upper tube, and blocks the cooled ATF from flowing back into the transmission.
When the fluid heats to ~180 degrees, the TBV begins to block the flow of heated fluid, and opens to let "cooled" fluid return to the trans. If the fluid cools to less than 180, the TBV again blocks the flow of cooled fluid, letting only heated fluid return. It appears that once everything is heated up, the TBV is letting a combination of heated fluid and "cooled" fluid return to the transmission, the percentage of each determined by the fluid temperature.
So how to disable the TBV? Simply removing the thermostat part of it and replacing the plastic, o-ringed cap would let heated and cooled fluid mix and return to the trans. Not sure that the end result of that would be much different than when the trans is fully heated and the TBV lets a varying mix of heated and cooled fluid return.
Even if the engine coolant lines were disconnected from the assembly (and connected to each other), fluid heated by normal transmission operation would still mix with the cooled fluid. So far I can't come up with a way to remove the thermostat part and block the flow of heated fluid without making that modification permanent , such as driving a precisely sized drift into that portion of the bore to block the return flow of heated fluid. I am still investigating.
Sorry for the long post.
