I don't have a fourth gen but I bet hemi fever has tunes for the more modern 8 speed. Lots of guys on you tube running their tunes.
Debating on purchasing a tuner here soon.
Any updates on if or when any type of transmission tuning will be available for the 8 speeds?
I have a 2014 if that matters.
My advise is not to play with any kind of tuners like Diablo. Find a professional tuner that will adjust your maps sitting in your car. You will spend several hours for the procedure, but in the end it will be a good result
A Diablo I2 w/ a email custom tune is all you need and really all you can get on these trucks. Jay Greene, Flyin Ryan or Hemifever tune gives great results. They are the 3 main go to guys for tuning.
Your advise is based on...what?
What tuning system are you eluding to? Maybe the system they use on street outlaws? .....not for a car/truck with a locked PCM.
For 90% of us a canned tune or CMR e-mail tune is awesome.
Even with FI / N02 it can be done in this manner.
At some point it does become worth the the expense for a dyno tune. My tuner did part of this while sitting in the car. He needed to do that to press the gas pedal.
Diablo has been used by countless people to tune their vehicles. Safely and with great improvements all around.
Yeah some folks have had problems, like with any product.
Back to your post...why would you encourage the OP to pay someone to tune my mostly stock vehicle while sitting in it for I'm sure a added expense, when he can do it himself with less of an investment in both time and money?
Further should the OP add to his build he would have to go back to that same point of service to have the tuning adjusted.
You will be hard pressed to go find someone that can tune better in person than Jay or Sean tuning through email for these trucks.
Yes...in the GM & Ford world an in person tune is better than an email tune...but this isnt the GM & Ford world
Why do you think it is for Ford and GM only? What's the difference? you have the same type of PCM that allows you to make all adjustments needed(excluding 2015+ with locked PCM).
There is a difference in adjusting of several points, as throttle for example. GM uses linear model, Chrysler it's own a bit more complicated, mirror styled and even with discrepancies in axis.
He is a guy living in Russia, member of HPTuners testers team. Quite professional one! He made a final tune for my 416ci twin-turbo Escalade. So that was a true challenge ))So who is tuning your Ram may I ask?
