Active grill shutter experiment
Jwithing
STL
did you removed the module after the tuning?
Sent from my SM-N950W using Tapatalk
Nope, didn't bother. It's ziptied and out of the way so it's there if I ever decide to throw the shutters back in. I know the tune is working cuz I did the screw trick wrong lol. After my screw trick, the plunger would pop the casing on the module open, even after gorilla glue lol. Sean was able to tune it out for me.
kidmandudebro
Connecticut
I want to try this and I'll drill a hole thru the 1st hole 11/32 and use a threaded bolt to go thru entire casing and have it closed on both ends using a washer and a nut on each end. I should find it all at home depot. I'll post pictures when I'm done.
I think is better to have air flowing in then trying to be more arrow dynamic and going over the hood.
