Markcuda
- Nov 16, 2016
- 498
- 248
- Clinton,Illinois
- 2015-Laramie-1500-CC-4X4
- 5.7
TheRudeDog, did you have to loosen the pan hard rod or the anti roll bar at all?
I sleep much better at night knowing my new rear end cover will never make contact with the stupid brace/what ever you want to call it directly about the cover welded to the cross member in the frame.
What is the official name for the thingy?
I did not measure the distance from the cover to the welded on bracket on the cross member, but, I did not ever want the two to make contact, now they never will.
It looked like about 4/5 inches from the cover, the yellow bump stops probably would of bottomed out first, not sure on that.
With a cutting torch, it took all of 1 minute to remove))))))))))
Are you guys filling the Mag-Hytec differential cover until it drains out the hole in the middle of the cover or filling until it's at the full mark on the dip stick?
Thanks
Take the bar off and grind some metal off where the bar might come in contact with the cover.This thing has maybe enough room for a credit card to squeeze between the panhard bar and the Mag-Hytec cover
20170221_061658_zps6pdgbxsh.jpg Photo by 1234567890a2 | Photobucket
That is 3 credit cards of space between the panhard bar and cover. Not a happy camper with the cover. I'm not a drivetrain expert but this looks a little to close for comfort for me.
