Alternator Bearings
nosepicker
Posting here to see if anyone has changed their ALTERNATOR BEARINGS?
I have confirmed its the front bearing of the alternator. She (bearing) is basically howling now at this point. This moring I replaced the water pump as that bearing was shot. I guess because the water pump bearing went and released coolant all around in there it seems to have spread the hate to the alternator bearing. Anyways....
If anyone has taken apart an alternator and put only "new bearings" back in the original alternator, please let me know what the part number or bearing dimensions please. Can't seem to find any info except a new alternator, which is a lot more $$. For no reason really.
Truck : 2011 Ram 1500 - 5.7L hemi SLT 4x4
Cheers
Jason
Burla
2010 Hemi Reg Cab 4x4
I dunno this might work, since they changed the name your year from Dodge Ram to Ram, I'm not sure they updated the application guide. Unless they changed the alternator in your year, this would fit.
DODGE RAM 1500 V8 5.7L 345CID 2003-2010
According to Amazon the alternator was the same for 4 gens through 2012, so that item should work, best guess. GL
I like your avatar name, you fit in just fine round here. They have kits for rebuilds, I don't know if you would need that or not to pull apart that bearing. Have you tried to remove the pully? Just spin that center bolt and see if it loosens.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Jason, I don't have an answer to your question but I just wanted to mention that it is refreshing to read that someone actually wanted to repair something instead of just throwing it away and replacing it.
Jay
