customcarz973
- Dec 22, 2016
- 84
- 39
- 2016
- 5.7
So, a little nervous to launch in 4wd with boost. Anyone with over 500rwhp do it? Did your transfer case live? lol.
Who has the supercharged regular cab. Im pretty sure he beats his up pretty bad in 4x4
That would be me and yes, launching in auto-4 without traction control will definitely stick you to the seat in my truck (see mods in SIG)
Done it for a couple years now with no damage whatsoever, these are tough trucks. As long as you have the 8-speed, you'll be fine...
4-auto only powers the tires when there is a certain amount to throttle or slip.
Do you always leave it in 4-auto the whole time or change it back to 2wd after the launch when you have traction to reduce some of the drag of powering all 4 tires?
Don't change it under power,things might go bang if you do,lol. Mine lasted about a dozen passes shifting it under power.If you're going to launch in 4X4,i'd leave it in 4X4 till at least the 330ft mark,i was shifting my T-case as soon as the tranny made the 1-2 shift,about the 60ft mark,and it didn't like it much.
Which transfer case do you have?
Same one as you have,mines a sport too.
So you have the 44-44 with 4auto then. That t-case will likely be less harsh on the driveline when switching modes under load, since it’s clutch based.
