Glefevre87
In the market for a tuner and CAI. What do yall recommend? I will be adding a Mufflex 14" in the near future and want to add some additional power.
As stated, either of the Diablo tuners paired up with a good custom tune is going to give you the best power gains.
As for intakes, the Vararam Air Grabber is going to give you the best performance, but the S&B has a more traditional design and a great fit/finish as well. Can go wrong with either of these intakes.
Considering a tune as well. I currently only have a carven exhaust installed, looking to do an intake as well and then a tune. Does it matter in order and/or with all else being factory under the hood? Wasn't sure about getting any engine error codes with the Diablo sport connected in. Main item with that is also disabling MDS as it is quite annoying when you want that full v8 power to kick in while cruising. Thanks!
It doesnt matter which order you install the intake or tuner because you get free custom tune updates if you go with the upgraded Hemifever tuning. Adding an aftermarket intake will not trigger any engine codes either, so there is nothing to worry about there.
