Currently have a leveled 8 speed with the 3.21s and 33's
What would be the difference in MPG if I add 35s (AT not MT) but also swap the gears over to 3.92 or 4.10?
is it 4wd ? If so, you have to replace the entire front drive line, not just the gears, for the front that is. Going up to that tire without a gear swap will give you about 13-14Mpg on the freeway, going to a 3.92 will probably bring you down to about 11-12 or so.
how are you guys getting 13-14 mpg's, i am at 10 mpg, no towing no upgrades nothing..
