This isn't warrantied?
You may not fall into this category but there is a Federal Emissions law that says the Manufacture must warranty any emissions related parts for 8 years / 80,000 miles. Exhaust manifold bolts would be part of the emissions system I believe.
https://nepis.epa.gov/Exe/ZyPdf.cgi?Dockey=P100AU05.pdf
"Emission Control Parts
1. Exhaust Gas Conversion Systems: oxygen sensor, thermal reactor, catalytic converter,
dual-walled exhaust pipe
2. Exhaust Gas Recirculation System: EGR valve, thermal vacuum switch, EGR solenoid,
EGR spacer plate, EGR backpressure transducer, sensor and switches use to control EGR
flow
3. Evaporative Emission Control System: purge valve, fuel filler cap, purge solenoid, vapor
storage canister and filter
4. Positive Crankcase Ventilation (PCV) System: PCV valve, PCV solenoid
5. Air Injection System: Air pump, diverter, bypass, or gulp valve, reed valve, anti-backfire
or deceleration valve
6. Early Fuel Evaporative (EFE) System: EFE valve, thermal vacuum switch, heat riser
valve
7. Fuel Metering System: electronic control module (unit) or EFI air flow meter, computer
command module or mixture control unit, deceleration controls, electronic choke, fuel
injectors, fuel injection units and fuel altitude compensator sensor, bars or rails for EFI
or TBI systems, mixture settings on sealed fuel mixture control solenoid, diaphragm or
other systems, fuel metering components that achieve closed/other feedback control sen
sors/loop operation switches and valves
8. Air Induction System: thermostatically controlled air cleaner, air box
9. Ignition Systems: electronic spark advance timing advance/retard systems, high energy
electronic ignition
10. Miscellaneous Parts: hoses, gaskets, brackets, clamps and other accessories used in the
above systems
Emission Related Parts
These are examples of other parts of your vehicle which have a primary purpose other than
emissions control but which nevertheless have significant effects on your vehicle’s emissions. If
any of these parts fail to function or function improperly, your vehicle’s emissions may exceed
federal standards. Therefore, when any of the parts of the following systems are defective in
Questions and Answers 4
materials or workmanship and have failed in a way that would be likely to cause your vehicle’s
emissions to exceed federal standards, they should be repaired or replaced under the emissions
warranty:
1. Fuel Injection System: fuel distributor
2. Air Induction System: turbocharger, intake manifold
3. Exhaust System: exhaust manifold
4. Ignition System: distributor, spark plugs, ignition wires and coil
5. Miscellaneous Parts: hoses, gaskets, brackets, clamps, and other accessories used in the
above systems.
