Cam
Garrettsipe
I have a 2014 ram express with jba shortys and a diablo tune and cold air intake what the best cam ??
charonblk07
Calgary, Ab
F1-A forged 349ci
That would completely depend on what you want out of a cam: low rpm torque, mid-range power, high rpm power. Do you daily drive it or plan to be a street/strip only? Lots of questions need to be answered and you should talk with a cam profiler like Dave at Modern Muscle, Matt at Moe's, or Jay at Greene Racing. You'll also want to look at the cost of a cam swap in a 4th gen and see if it's something you really want to do.
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
Is swapping just the cam worth it?
charonblk07
Calgary, Ab
F1-A forged 349ci
It totally depends on what you want out of the truck. If a cam swap is your only mod then I would say no just because you'll get more power out of full bolt-ons and a good tune than you will get out of a cam swap. A full VVT cam swap can easily run you $2K once you get the cam, springs, limiter, etc and most mid-level cams will get you 50-60hp but will change your powerband location. If you're setup with most bolt-ons and want to move to the next level then a cam swap is what you need.
I wouldn't recommend anybody do a cam swap just for towing torque because the gains are minimal for the cost and you will see better results from a higher gear ratio if you need the down-low grunt, but if you're looking for better power for racing then it's a no-brainer.
