Catch can?
VB712
Maxi_built
Va Beach
Is a catch can for these trucks with very few mods really beneficial? I just don't want to spend $140 on one if it's not really necessary. Thanks
huntergreen
Yes it is worthwhile for keeping the throttle body clean. Bt seems to be the most popular.
R/T_Fire
Pleasant Grove
Plus it adds about 45hp to boot!
That's only if you get a yellow one...
They are beneficial in the keep oil "clean" and intake/throttlebody clean. It gives a place for oil and moisture to collect and keep the crankcase ventilation going back into the side of the throttle body and back into the engine.
best way to describe it would be a dust mask for your lungs while sanding.... not needed but keeps things "cleaner".
To me its worth the $$$ even though it doesn't add HP, makes for a happy motor
NOcasio7
Tampa Florida
Not sure if its necessary but I did buy one and check it occasionally and do see some gunk in there so I would say it does work.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Answer to your initial question---YES
Jay
jag1886
Boise Id Gods country
Demi 5.7 S&B CAI, flowmaster merge collector, Gibson cat back, oil catch can, 87
A catch can is a totally unneeded piece for a stock truck IMHO. If you really have to have one watch for a used you for 1/2 price in the ads here, you see quite a few used ones. I have one but only because I found a cheap one, I have dumped mine once after 6 months it had maybe 4 tablespoons of oil in it.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
I empty mine at every oil change and usually it's about 1/4 full.
Jay
Mineralram
catch can shouldhe your first mod before anything else
jaycabral27
Hamilton, Ontario, Canada
I don't know if it's the cold weather but my hemi in the winter will almost fill the catch can in under one oil change
Sir John
Buffalo, NY
2016 1500 Rebel "Mopar 16" Special Edition
Yes, you'll get a lot more condensation in the cold months which fills the can quicker.
R.L.K.
Bristol , Tn.
LOL , sounds like you need to replace or clean your PCV Sir ?
R.L.K.
Bristol , Tn.
Read this thread and decide for yourself. .. I vote yes on an OCC for the obvious reasons of just keeping all the oily junk out of the air intake ...
http://www.ramforum.com/showthread.php?p=1255948
Hope this helps !
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
When my truck was new it barley had any blow by, had to empty it every 3-6 month and still only would be half full. Now that my truck has 55k and some really hard street and track abuse its half full or more every 30 days, so for me it was worth every penny.
Tray Burge
On the porch
I wish I could put one on my '03, not only for the obvious reason, but they cool too. Does anybody know if there's a way to bypass my internal system and add one? It sux having to check the throttle body blade.
