Have a 2010 Dodge Ram with a Hemi 5.7 and son spun a bearing.
1. how do you get the fan clutch assy. off?
2. can you remove the crankshaft without pulling the transmission?
3. is there enough clearance by pushing the torque converter back that the flywheel and crankshaft will slide out?
4. is the rear main seal set up that will allow the removal of the crankshaft from underneath without pulling the transmission?
I am very mechanical, just have not worked on a Hemi, or change a crankshaft with an automatic transmission.
Thanks
Chris
Thanks
Chris
