- Jul 31, 2015
- 2,736
- 1,951
- Delaware
- 2017 1500 Express 4x4
- Pentastar 3.6L
.......... Also it spit out a C3F03 code, what's that?
"C" codes are usually a chassis codes but will usually follow all numbers after the "C".
C3F03 is a classic hexadecimal code that converts to a 16 bit binary code of "1100 0011 1111 0000 0011". If I was to guess, that is a code only for use at an engineering level to be decoded by a source control document and not meant for end user interpretation.
Did you have a check engine light when you got this code? If not, might have just been part of a pending code that was waiting for another event trigger to post the check engine light.
