Crazy to want true duals?
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
I am wanting true duels put on my 2500 in the worst way. I have never been this anxious about getting a mod done to any of my vehicles. I guess it's cause I have this big brute of a truck with no rumble what so ever.
Does anyone know for sure that doing this doesn't void the warranty? Every vehicle I have done before the warranty was long gone but this baby doesn't even have a thousand miles on it yet.
Lees10ram
Ill get some as soon as I can. Adding tail pipes this weekend
14hemiexpress
Texas
6.4l
Here is a old system I did on my 06 it's dual 2.5 with magnaflow round mufflers and a h pipe. It sounded pretty good, mds drone wasent nearly as bad as the magnaflow xl chambered I had on there but was still present. https://youtu.be/rBoXPwx-qK4
Ramrt1
Oakdale, La
2012 Ram 1500 R/T
I have had quiet a few exhaust since I purchased my truck in 2012, 68k later I have decided that a properly built true dual system is where my heart is. In combination with my custom tune, headers, vararam, 87mm throttle body, and 180 stat my truck runs stronger than it did with my other exhaust set ups. I now have a 2.5 inch x pipe with custom built exhaust cutouts going into 2 pypes m80 race mufflers followed up with 5''inch tips. It's the best sounding and performing exhaust I have ever installed. Hellcat sound in a truck.
SyN
6.7L CTD Owner
Tornado Alley
2017 4WD - Tow Prep Pkg - Off-Road Pkg - 3:42s w/Anti-Slip
6.7L CTD
This is my opinion of a perfect exhaust for the 5.7L... Either the Flowmaster/Magnaflow cross flow muffler could be substituted for the Demon exhaust...
5" Tips would be a plus as well...
Kinney's creates one smooth flowing exhaust system...
https://www.youtube.com/watch?v=qG7H6xIKWzU
BlownGP
Houston/Baton Rouge
My friends truck (in my avatar) has true duels with magnaflow mufflers.
It's got a deep sound, it's sorta quiet to me. It does get loud under WOT but not as loud as mine. Which has a flowmaster single exhaust.
BlownGP
Houston/Baton Rouge
That almost has a hollow mustang sound.
I like it. Wonder how much that cost.
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
I agree on the Sound! Just pure Muscle Car sound-->No Hillbilly/Redneck sounding there...
As for cost... I have no idea! Kinney's is very proud of their work / but their work is dam near perfection...
https://www.youtube.com/watch?v=VkAfu4UlfoM
Their shop is some where within the Dallas/Forth Worth area...
BlownGP
Houston/Baton Rouge
Yeah, I looked on their site and watched some more video's. It does look like they do very nice work so your probably right on the price. lol
choquette
CUMmins 6.7
You are right. Exhaust is just very hard to explain through words because sound will change based on whether you use an X or H pipe, where you place the X/H pipe, where you place the mufflers, what size piping you run, with headers or without, what size tips, etc...
If you are going with duals, I would switch to 2.5" piping with an X pipe just behind the transmission crossmember, and then mount the mufflers in about the stock location and keep the stock 2.25" tailpipes out back. Pair that up with a set of 5" tips, and it will have a very nice growl to it.
Thats what I did but without the 5'' tips I kept the original ones! Put an X-pipe near the trans and changed the muffler for a 14'' one from magnaflow! Best sound I ever heard! I could try the 5'' tips tho!
Ramrt1
Oakdale, La
2012 Ram 1500 R/T
I really love the way my exhaust sounds now, and I have had many. It sounds more old school. It's very aggressive on start up, rumbles at idle, mild when your cruising, but all hell breaks out when you get on it, gives me chills.
jonathanhudaon
Hey Hemi450hp,
Is there any advantage with changing the 2.25 tails to 2.5” (for true dual or even just single to dual exhaust) or no? Was thinking of upgrading my tails to 2.5” if it’s worth it.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Hey Hemi450hp,
I would say it's not worth the money to change it. In fact you can get to the point where you lose too much back pressure & you can start losing low end torque.
You do want to get rid of any bottle neck the exhaust might have. On my 2500 with the 6.4 the "Y" pipe from the factory was really bad. I ended up putting true duels on all the way to the back, but even if I just replaced the Y pipe I would have created much better exhaust flow.
