jlb
So I am thinking about making a custom CAI. I saw somebody on here had a pretty sweet little job with some aluminum tubing, and a cone filter, but I was thinking about trying to take that a step further...
I have an opening under each of my headlights that is relatively large, say 8in by 3 in tall. I was thinking I could run a y-pipe directly off the TB of my truck and send a 3-3.5" pipe in each direction off the top of my block. If I get particularly motivated, or stuck, I would consider moving the battery to where the airbox currently resides.
I could custom fit a box for each side (thin tin, rivets, and some silicone sealant) with the filter inside, and then run a similarly made "ram" under each of my headlights. I haven't really put much thought into this I am just kind of tossing ideas around ATM.
The thing I am most unsure of is what to use for tubing. I want something relatively solid, like pvc, that insulates against heat a little (which is why I don't particularly want aluminum), but that I could fit into the shape I need. I was thinking some type of heat shape vinyl would be good, but in 3in+ form it would be pretty expensive.
I was thinking I could do this project for $150, and have a pretty sweet intake that would MAYBE build 1psi, or even 2... but would certainly not limit flow at all. Also, it would look pretty BA with two filters, and a ram on each side lol.
Thoughts? Call me a *******? Tell me to just buy an aftermarket CAI? lol
