Diablo Trinity Throttle Adjustment
boomer632
Been reading posts on the Pedal Commander. I like the idea but i don't want a until hanging from under my dash. Am I right that the Diablo Trinity has the capability within tuning to do what the Pedal Commader does a module?
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
I beleive it has a throttle booster function that you can adjust. That may it.
BossHogg
Oakland Township, Michigan
6.7L Cummins
May want to research this before plopping down your hard earned coin. The guys on the Cummins forum say no tuning software is addressing the throttle response the way Pedal Commander or the BD unit do. I don't know if the same is true with the Hemi engine controllers.
WadXpress
HEMI
Yea it does. Turn it up 20% and it wakes up the throttle response and makes the truck a lot more fun to drive
West27
2014 Ram 1500
Are you running a custom HF tune and also turning up the throttle response? Sean said he already adjusts that in his custom tune so I didn't mess with it on my truck
monteholic
Michigan
6.4 hemi
I'm curious about this also, on the fence right now about Itune/hemifever and starting to lean hard about pulling the trigger
West27
2014 Ram 1500
I can say I'm 100% satisfied with Hemifever. Sean has gone out of his way to help me with my tune once I updated my truck from dodge and then the tune was causing my 8 speed to shudder. Now it shifts amazing and couldn't be happier with the power. Truck stock ran 0-60 around mid 7s and now it runs high 5s. Taking it to the track next month to get 1/4 mile times!!
monteholic
Michigan
6.4 hemi
all I care about is better drivability (throttle response, trans shifting, towing) it has more than enough power for what I use it for
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
You have throttle boost and throttle up shift on the t1000. Throttle boost makes it a little more responsive, and the throttle up shift (only way I can explain it) is taking the slack out of the throttle/peddle. Custom tunes the throttle boost is layered differently between the gears.
