Mrjesse2500
- Jan 4, 2016
- 24
- 4
- 2010
- 5.7
I posted about this before and I still have the same problem but now a little bit more specific. I have a 2009 Dodge Ram 2500 and I'm having misfires on cylinder 3, checked sparks and they're good. Injectors and coils great too. There is a "ticking" sound which I know is very familiar on the 5.7 engine but the thing is that a mechanic told me it was a stuck lifter. He swears it's the lifter but surfing trough the internet I found somewhere that a bad lifter will make noise no matter the rmp, is this correct? Because that ticking noise goes away after 1500-200 rmp. Now, there comes the awful part. Whenever the truck accelerates anywhere past 2000 rmp it shakes and the engine light comes on. I know that is a misfire of course but it's happening very often now! It usually happened only when flooring it or anywhere past 65-70 miles. Now even with 40 mph it gets that misfire. I checked the code and it only says a misfire on the cylinder #3.
The truck used to drive great, no issues at all until one day i noticed a small shake when braking and accelerating. Only 2-3 seconds and that was all now it got worse! Please if somebody can help me figure this out I'd appreciate it so much!! If you think is the lifter, any recommendations of tips to make it work? I don't want to spend thousands of dollars to get those replaced! Unless I have to of course... 2009 Dodge Ram 5.7 hemi
