Does not start on first try
Abbottma
My 2500 6.7 clicks on first couple of try's the cranks normally and starts? Batteries check out good? Only happens when vehicle sits overnight or longer? Fires right up the rest of the day. Any suggestions?
RamCares
Michigan
n/a
n/a
Hi Abbottma,
I checked on my end to see if there are any TSBs or STAR cases--there is a STAR case your dealership could reference, S1308000399, that involves checking the fuel pump relay. If I can help make an appointment at your dealership, please don't hesitate to reach out!
Kori
Ram Social Care Specialist
A
Abbottma
Thank you Kori, I will look into that? Today it did something different. It actually shut down shortly after starting. Same sequence of clicks leading up to the engine turning over and starting?
RamCares
Michigan
n/a
n/a
Just keep me posted if I need to reach out to the dealership for you.
Kori
