beveballs127
- May 6, 2016
- 18
- 4
- 2013
- 5.7 hemi
Need a little help pin pointing a transmission issue. My truck caught some wheel hop when it hit second gear on a burnout. Exploded the ring and pinion. I fixed the rear end but now the truck does not want to move after a few feet. If the truck is in 2wd in drive it moves 10ft and then free revs. In 4x4 high it does the same thing. In 4x4 low it will keep moving. In reverse it will keep moving. I'm thinking that this is an indication that the torque converter is bad. It does make a faint noise but nothing you can pinpoint. Im ready to replace the pump and the torque converter as I'm 90% sure that is the issue. I would just like the hear some opinions and maybe someone can share their experience especially if they had a bad converter or pump. Thanks in advance!
