EGR Delete on 4th Gen
Joshwaa
Lake Worth, FL
2016 CC 4x4 Laramie AirRide
Has anyone done the egr delete on a 2015+ 5.7 Hemi?
Wondering where it is located on the motor. It is no longer right up front like my 3rd Gen. Also if you have done this is the tune still able to block the CEL once it is removed? Thanks
charonblk07
Calgary, Ab
F1-A forged 349ci
There is no EGR on the 4th gen engine, only the PCV.
Joshwaa
Joshwaa
Lake Worth, FL
That's what I figured. I was looking all over the back and front of the heads and could not find anything.
JasonK94Z
Moore, OK
Where is the PCV valve located? Needs replaced once in a great while right?
RedAlert
Take the intake tube and plastic cover off the motor. Look towards the rear passenger side of the upper plenum and you'll see a square box with what looks like a wingnut on top. Thats' the PCV valve and housing. 1/4 turn of the wingnut and pull it straight up. Can be a bear to get out the first time. And don't fall over when you see the price of a new PCV for these motors.
VLG6963
