Exhause manifold bolts broken...common?
skirider
This is the first im hearing of this issue. I have a 2011 with low miles 3000. Is this covered under powertrain warranty? nd is thers anything i can do as prevenative maintenance?
What was the powsrtrain warranty. 100000 or how many years
14hemiexpress
Texas
6.4l
I just replaced 2 not that long ago. My driver side top front and top rear heat shield studs were broke. I used extractor on one and welded a washer on the other then welded a nut to the washer and got it out that way. For money sake I just replaced the maifold (stock was warped) and repalaced the bolts. When I bought the truck previous owner said the passenger side was done and the heat shield is tight and no ticking.
14hemiexpress
Texas
6.4l
The one I used the extractor on.
14hemiexpress
Texas
6.4l
The one I welded. If I had advice for anyone wanting to atempt this I suggest just welding to start with if you or a buddy can weld. I spent hours drilling just because I wanted to prove to myself I could do it and not mess anything up. It took 5 min to get the one out I welded. But I can say I did it.
RamCares
Michigan
n/a
n/a
I recommend visiting the dealer for proper diagnosis. To see exactly what is covered under your warranty please visit Ram Trucks Warranty - Pickup Trucks, Work Trucks & Vans. Thanks! – Kevin T, Social Connect Team
bubbasneed
Cincinnati OH
Are you guys changing the gaskets also, or just the bolts?
DILLIGAF
Canada
Will the 6.4 Hemi header gasket work on the 5.7 ?
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Shop tells me 2 of my bolts on my exhaust manifold are broken clean...and I need a new manifold and have them drilled out because it's making me run rich due to lack of back pressure.??
First...how much fuel will I be losing just by this?
Second...how common is this? They said it's very common on Rams.
Third...is this a MUST fix? or can I live with it?
Very common on 5.7L Hemi.
Sorry you are out of warranty, but you need to get this corrected.
Rampant
NJ
392 Hemi
Gaskets are the same between the two engines; exhaust ports are the same on the 6.1L, vvt 5.7L, and the 6.4L.
Here are the MOPAR part numbers using a 2014 2500:
5.7- Current Rock Auto Price
RT Manifold- 5045486AA $63.79
LT Manifold- 68045559AB $106.79
6.4-
RT Manifold- Same as 5.7 $63.79
LT Manifold- 5045485AC $135.79
Gaskets for 5.7 or 6.4-
RT Gasket- 5045496AA $14.29
LT Gasket- 4893789AA $26.99
charonblk07
Calgary, Ab
F1-A forged 349ci
6.4-
Good info. The exhaust ports are the still the same, the manifolds are different but the port shape is the same, just for clarification if that wasn't clear.
kg93
AZ
6.4-
I was looking to take my jba headers off and recoat them since they got all rusty. I might as well replace the gasket and throw stage 8 bolts on there. Those are the gaskets i should use correct?
Rampant
NJ
392 Hemi
From what I can tell, the only difference is in the left manifolds themselves. I pulled up the gaskets from three different sources and they all came up with the identical part numbers.
charonblk07
Calgary, Ab
F1-A forged 349ci
Yes they are.
spymac
2011 Express
Hemi 5.7 - 390HP
My 2011 hemi with 36k just had this issue. Dealer replaced manifold, broken bolts and gasket under warranty. It was the passenger side rear bolt/stud that attaches to heat shield that broke.
Bee1971
Sobieski WI
2011 Sport 4x4
345 Hemi
I want to replace mine before they break
Will those grade 8 header bolts work with the factory exhaust manifolds ???
And has anyone just brought there factory exhaust manifolds to there local machine shop and have them planed or resurfaced ???
I have a local machine shop that I just had my 71 Bee exhaust manifolds resurfaced at this past spring for a case of beer - They did an awesome job on 45 year old factory original manifolds for my 383 Magnum
RedFlameRam
