Expectations of a Stock Hemi Ram
Shambo
O.K. I have not been in the Gas performance world for a while (i was a Diesel Racer) I have a 2011 Ramp Quad Sport, Stock with a Posi installed. I tries to power brake a burnout and it really would not do it on Dry ground, but when I let off the brake I got a chirp of the tires, and yes traction control was turned off. Is that normal? Will just a programmer fix that? or what Mods has everyone done to get the low end performance increased? what are the stock Quarter times expected? And finally what will a intake, Throttle body and Programmer do for me in the quarter mile times.
Thanks In advance.
dearchristopher
Galveston, TX
Thanks In advance.
mine breaks over very easy on dry pavement. 11 with a 6 speed and 3.55LS rear. if I stomp it will break loose and I'm all stock. if I power brake I can spin for a bit. I do know there is a ton of torque management in the stock tune, the hemi makes its power decently low so they granny tuned it at a lot of points. a lot of guys like the shift points of tow haul mode including me. I think intake, 89mm throttle body and a good tune should get you close to 13's pretty reasonably. hemifever tune is what I've seen guys talk about. check out moes performance for all the parts you'll need
Sent from my LG-D850 using Tapatalk
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
What gears do you have? Is your truck 2x4 or 4x4? Times vary from 12.5 to low 15's depending on mod's. Low gears and a tune will give you the best bang for your buck.
Jay
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
Thanks In advance.
Traction control is never turned off (unless you have a tuner). The best you get is maybe 50%, and even then, if the rpm gets up to 3000, it will cut spark & fuel to limit wheel spin/power.
At least that is what I determined one night testing it in some snow.
jackblackjeet
St Louis, MO
2014 5.7 8speed with 3.21 and with traction control button off, they spin quite easily. However, I agree with TRCM they spinning does seem to fade out much earlier than it should. With traction control button on, it's a little chirp and then punishes me with no throttle for a few seconds.
Galion
Edmonton, AB
Thanks In advance.
Since the others seem to have answered the first part I'll take this one. An intake might gain you a little bit, the biggest difference you can make will be a tuner, the most popular around here for hemi's being the Diablosport trinity with hemifever tuning. As for the throttle body, imo it's really not worth doing the throttle body without doing more supporting mods beforehand. My route personally would be Tuner, full exhaust(not just catback, the y-pipe is by far the most restrictive part on these trucks), CAI. From there you can go into deeper mods if you're so inclined. But that would be my starting point at least.
S
Shambo
I have some friends at super chips and As I understand there is torque management in the software that is causing this issue. So Programmer is on order!
Thanks Everyone!
Ratket
Arizona-
canned tunes from a programmer are ok- but no where near as good as a custom tune from hemi fever or jay greene. I am not sure if either of them support the " super ships" programming but I know they support the Diablo platform. Personally you may want to go with Diablo for this reason alone.
Reactions: SyN
CMil527
Old Bridge, NJ
2021 RAM 1500 LARAMIE-CC
the programmer will give you most bang for your buck!
Reactions: SyN
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Superchips is not custom tunable unless his friends are able to get him a 1 off tune. I know they used to do that for a few of their locals years ago. Superchips as a company has gone through some major changes since then though, so I don't know if that is still the case.
As everyone has said, tuner, gears, and tq converter will show the most noticeable gains in off the line power.
poweredbyhemi
I too am coming from a tuned 15 powerstroke & i can't see any power to be had from a ram 1500 powertrain,just try not to bang your head to hard & save up for another diesel toy & just drive this thing.
As the only way i ever see my new sport being fast is if it gets a hellcat powertrain transplant,otherwise it just isn't worth trying to obtain the impossible.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
20" rims are also a ****** to break loose. It takes almost no moisture at all and they will break clean, but dry pavement with the stock Badyears and the torque management will hold you to a chirp at best.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
There are plenty of basic bolt on hemi trucks running anywhere from mid 12's to high 13's in the 1/4 mile. It doesn't take much to make these trucks quick. Of course you aren't going to gain 200hp/300tq from a tune like you would from a hot diesel tune, but its not hard to make these trucks run just as quick as the bolt on and tuned diesels.
Kotta390
Texas
From what I understand, by turning off traction control, it does not mean that the traction control is FULLY turned off, just like 70% or something...
S
Shambo
I just want a little more from the truck. What I don't want is a Transmission eating truck! LOL Been there done that! I personally know the Superchips guys from my Diesel Racing days so I have loyalty, and I'm not in the racing circuit anymore!
The opinions You all have given is excellent and have verified my thoughts. I appreciate it Guys! So I will now see what happens with my new toy!
S
Shambo
Just bought the Programmer from Ya! and The Limited Slip I bought a couple of months back is doing well!
Mo's Performance is awesome!
