Factory 2014 battery
VB712
Maxi_built
Va Beach
Started my truck yesterday morning to go to work. Battery sounded weak. Got off this morning, same thing a little weak starting. Went to start it tonight and she was dead. Had the battery tested and only had 312 CCA. Original battery. Only 3 years old. Replaced battery and all is well. Anyone else have issues with these factory batteries?
07MegaCabRam
Chandler, Arizona
6.7L CTD
Mine was about 2 years old. Had to replace both. My buddy, who bought his truck the same day i got my truck, 2-3 weeks later, he had to replace his too..
jasonw
South Dakota
5.7L Hemi V8
Thought mine was a tad weak, had it tested at O'Reillys a few months ago. It tested good and strong, so I guess I'll stick with her a bit. Got a jump-starter for my birthday last month (the real kind that AAA carries, not the little lithium ion packs), so if it does die, I'm covered enough to get myself to an auto parts store (or home).
huntergreen
Had my stock battery in my 11 when I traded for the 16. Battery was still going strong.
West27
2014 Ram 1500
My stock battery in my 2014 just went to **** also and I had to replace it.
mtofell
Batteries always seem to have a lot of variation in service life. Usage, temperature and just luck I think all have a lot to do with it. 3 years isn't terrible. I'd bet you're getting into the "meaty part of the bell curve" as George Costanza says (Seinfeld reference for those of you who aren't familiar).
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
Stock Mopar batteries are complete garbage. 2-3 years is about all you can expect to get. Right at 2 years the one in my '12 Wrangler took a crap. Jeep replaced it for free. Another 2 years and it died again. I replaced it with a Deka and it's been good since. My truck was the same. 2 years it was deadski. Replace with Exide at the end of 2014 and it's been good since.
Those mopar batteries rarely show signs of their impending doom. They just die. Suddenly. Without warning.
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
Batteries are like women :eek: some last a long time and never give you problems , some are a royal pain and do not last :O so it is the luck of the draw! The battery in my 2011 HHR is factory and running strong even at 0*f and below ! My 2015 RAM so far is real strong as well at 0*f and below !
Also depends on if the battery was made on a Friday or Monday on how long they last lol
ExpressRules
Southern New Jersey
2014 Express Crew Cab & 2019 Big Horn Crew Cab
The battery in my Ram is over three years and still going. Original battery also in my 2012 Jeep.
VB712
VB712
Maxi_built
Va Beach
Yeah I pretty much had 1 day of noticing my battery was weak before the truck wouldn't start anymore. Pretty crazy. The factory batteries in my 2012 cummins never gave me any issues.
tantore
texas
hi guys my 2012 ram original battery still going strong after 5 yrs hope it will last another 2 yrs.
Hipps2000
2013 Ram 1500 Bighorn
Hemi 5.7l
Still running my late model 2013 oem even have an ATI pulley as well as 2 amps and 12" sub. Question is what is the best battery to upgrade too...when this one goes I would like to purchase a quality high end.biggest CCA I can squeeze into the oem spot. Any suggestions
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Wow that seems a little pre-mature! My old 04 Dakota still had the original battery in it when I sold it in 2014! Guess they don't make them like that anymore.
mohemipar
Michigan
2017 Laramie
6.4 Hemi, 4.10's
Still have the factory battery in my 2013. Still starts strong even in the freezing cold. Was planning on replacing this coming fall, so hope I make it.
WilliamS
Tampa FL
My factory battery went from a full power start, to 5 minutes later couldnt keep the lights on in the truck a cell went bad in a short drive leaving me stranded 28 miles from home. Mine is a 2014 as well this was about 3 months ago.
Riccochet
That's what happened in my Jeep. Nice, powerful start, made a 30 minute drive. Go to start it when leaving and it wouldn't even click. Completely dead. Called CCC, they towed it and found the battery with dead cells. Replaced. 2 years later same thing. Started fine in the morning, completely dead at noon, bad cells. Then again in my truck.
Maybe I just have bad luck, but I'm not one to press it, so went with different brand batteries that I trust.
AzCats
Portland OR
2014 1500 CC Laramie
My 2010 Powerwagon oem battery died at 60k 2 years old and 2012 Ram 1500 CC Hemi oem battery died at 65k 3 years old
my friend's 2010 Powerwagon oem battery died 61K 2 years old
TRXHemi
Sugar Land, TX
My 2010 battery lasted 4 years and 125K.....
My 2014 was about 2 yrs old.
VB712
VB712
Maxi_built
Va Beach
Makes me feel so what better. Mine just randomly gave up. Had it tested and only had 312 CCA. Installed new battery and had the charging system tested just to be sure. All is well.
shauncnoel
2014 Ram 1500 Express
5.7 Hemi V8
Just replaced my stock battery today after taking it to the dealership for a few recalls and saw how surprised the parts manager was when he saw I still had the stock battery in there. After asking them to test it they informed me that it was pretty well close to the end that the stock batteries they install only last 2-3 years tops. He said I broke the record
1Popeye
