I see a lot of tuners being suggested as first mod. Can my bone stock truck really improve from a tune, if so I may have that done first. Sounds like their is some potential with just a tune.
I'd say tuner by all means. I drove a 2016 sport rt just yesterday and couldn't believe how bad the calibration was. The thing nosed over at or near redline in first for over 1/2 second, then took off again. And it was not impressive for 395 hp and 3.92 rear in standard cab short bed. As to cold air, you already have that stock and other than a filter of choice it probably flows plenty.
I doubt that you aren't impressed by the 395hp. What you aren't impressed by is the ungodly amount of torque management that is calibrated into the truck between shifts. Such things include, heavily reduced timing and throttle closure. I have logged some of the tq mgmt at the shift point and the truck can pull anywhere from 18* - 22* at WOT. A tune with just some of the tq mgmt reduced makes a massive difference and that's not touching the actual fueling or timing during acceleration.
So can the torque management be modified by a tune?
Could you please elaborate on what you said by saying the truck already has cold air stock ?
Every aftermarket cold air kit I've seen draws from the same place....
