The additives in your gasoline should require no additional cleaning of your fuel system, the reason additives are in the gas to start with, at least in the US and I can only assume Canada is the same.
So buying additional fuel system cleaners is simply wasting your money unless you are getting the "feel good" in return for your hard earned money.
You are free to have an opinion and exercise it in caring for your own vehicle--even be a skeptic if you insist.
But you should not provide intentionally bad advice to others. Just as certain materials in fuel varnish metal, certain chemicals can dissolve those deposits without disassembling the engine. More importantly, these additives do no harm, unlike your advice.
Eschew additives for your own vehicle if you want, but I would suggest forceful advocacy against them is a disservice to those with a less calcified set of beliefs.
I have to ask when was the last time you took apart a gas engine that had seen nothing but oil and plug changes over its life, especially one that has done a lot of short trips in cold weather--or had to rebuild heads because the valves or valve seats were failing? The combustion and induction systems are never spotless--oh no, far from it. Diesels can be even nastier when they finally go.
1) The design of the Hemi PCV
ENSURES there will be varnishing and build up in the induction system from the entrained motor oil and combustion byproducts in the blow buy it evacuates. A bit less so in OP's 3.6L, but the principle still applies.
2) Gasoline breaks down over time in the dealer's tanks and the vehicle's tank. Gasoline also has component parts that breakdown and change under heat--before ignition, and that includes more than just ethanol, or entrained water. This occurs for example, when in contact with the hot metal of the intake valves since the Hemi is not direct injected. Add in the PCV waste for engines without catch can protection and the induction system WILL varnish-up and build deposits over time.
3) Injectors can also varnish over time. You've got a diesel and its even more common to clog injectors there--and diesel fuel is even more likely to carry unwanted junk or micro-entrained air that pounds your injectors apart--but that's a different discussion.
4) Exhaust valve seats in particular collect combustion by products that impede valve sealing and decrease engine output.
