arod412
- May 14, 2012
- 1,585
- 308
- Philadelphia
- 2012
- Hemi 5.7
So I'm trying to make light of a situation that plagues me every oil change for my 2012 ram hemi. It's the damn f'ing location of the oil filter. It's just horrible.
So this past weekend I aimed to perform my 3rd oil change on my ram. I've had it for almost 4 years and I have never done any Do it yourself projects with cars, so I am determined to just learn the in's and out of working on my truck, and that starts with the simple task of changing the oil. Got to learn somewhere, right.
So earlier in the day (this past saterday), I changed the oil for my loving girlfriend's 2012 ford escape. Oil filter is right in the perfect spot in the front..no restrictions to access it, and draining the oil and replacing the filter was piece of cake. 15 min job, including finished drinking my corona. I knew that my ram, was going to be a bear, so I pushed it until after her suv.
On to the ram. Knowing that the oil filter was right above the steering arms and higher up. I knew that oil was going to be everywhere. I gently place some aluminum foil around areas so **** doesn't get messy for me. Apparently. It doesn't matter, because the oil filter itself just didn't want to come off even though I hand tighten it (I'm guessing just a little past after you feel resistance) and the ***** didn't come off. Sat there for 20 mins trying to pull that **** off, and it didn't happen. So I had to go to the auto store to buy an oil filter wrench, came back and finally loosen it up just a tad so I can get my hand in there. Finally with rubber gloves on I finally turned it so the oil spilled all over the ******* place..down my arm, on my shirt, in my face...just everywhere, even after I took precautions on where it was going to go. That location of the filter is just brutal.
So that was my long ass story when trying to DIY. You can laugh now...but i invite you to post your own DIY story...it could be any auto (different makes and models are welcome)
P.S. to make amends for all of it, after the oil change, I replaced my radio head unit to something nicer. Also, I don't mind if this become a general repair funny story and the thread needs to be moved outside of the engine topic. I'm just putting it here because of the oil change situation.
So what's your funny situation when working on your truck?
**Truck name: Rampage**
