PCT
2019 2500 6.4
- May 9, 2014
- 2,107
- 475
- Northern California
- 2019
- 6.4
Past few months I have noticed my mpg in the trash! Cruise control set at 70 on flat ground I'm getting 11-13, where I used to get 14-17. Engine seems to struggle to stay to speed while in 6th. Truck seems to produce power alright when giving it throttle, no hesitation not worried about not making a merge or what ever on free way, it's just when crusing. Truck does fine in city, and idles very very smooth.
According to evic i am at 203 coolant temp while on highway. (Oil reads -43) for some reason the 4.7 doesn't report oil temp. Trans temp at 153.
Ambient has been 80-105
I have used half a can of seafoam through intake (spray version). Cleaned air filter, put oem air hat back on, put a full can of seafoam in gas tank. Upper set of plugs have been done 10k miles ago, all fluids on drive line have been flushed or changed. I take great care of my vehicles so almost everything required has been done. I do see a lot of oil mist in the intake manifold, but catch can will fail can smog.... Few things I think are causing, the oil soaked manifold, or when I was loosing my job I used only Safeway gas for about 4 months straight, so maybe the injectors are dirty... Some have mentioned pcv being plugged, and egr being plugged. Gotta pull the pcv valve and clean it, just don't wanna break anything pulling it off. If anyone could steer me in the right direction.
