Gas mileage. Help
skirider
2011 dodge 1500 v8 hemi
Put on some 35 nitto trail grapplers on 20s
Knew i would drop gas mileage average. Around 13
Towed a 2000 pound trailer and droped to 9
Also was kinda struggling kept shifting
Out these tires really hurting me?
Thinking of going back to normal snows for winter
Do u think it will make it better.
TruckNut
Tennessee
Did you allow for the diameter change in calculating your mileage? Check your odometer against mile markers if you haven't recalibrated speedo. You may be doing better than you think.
S
skirider
Speedo has been recalibrated.
3.55 gears
Shifting is up down whole ride crusing at 70
I would think pulling 2000 lbs truck would barely know trailers there.
Bigdaddycodes
Swift Current Saskatchewan
do a gear swap and it will really help, go to a 4:10 or even a 4:56, turns those tires easier, I picked up a good few mpg on the highway after going to 4:56 on my third gen. and a lot peppier
MADDOG
Out Exploring Arizona
Next time you tow try Tow/Haul mode.
35's not only add frontal area and cut down on your aero but they also add weight. Both of those will hurt MPG.
But I think you'll see better mileage in Tow Haul vs. full auto when towing.
monteholic
Michigan
6.4 hemi
and change the effective gear ratio
JJP71584
Pgh, PA
Also I would consider a tuner if that's an option, will definitely help
Sent from my SM-G935P using Tapatalk
S
skirider
Tried tow haul mode. Did not seem to make any difference.
Gear swap sounds expensive.
Dont mind it when not towing
Wouldnt mind getting a cheap take off rims and snow tires.
Tuner option. Intune?
yillbs
what ? the final drive ratio in the 8 speed will fix this. Adding lower gears is a waste of cash, your overall MPG won't be affected. The final drive ratio on this 8 speed is like 15:*.....
With that said, if you're getting 13MPG with those 35's , be happy. I have 35's, and I'm getting 11.5 :( i'm likely lifted more than you, but still, 13 is decent, i've towed 8k with it, and i'll get about 4 - 5 depending what state i'm in. good luck :)
