Governor??
Lawhand
Baton Rouge, LA
I would be more worried about ur tires over 110. its limited for a reason, and me thinks the stock tires r rated at 110 mph. SPEED is not cheap :)
its an electronic gove system tho which can only be tuned out. Wish bullydog had the tune for 2012's... they r a cheap and easy tune system that works to my liking
garner
Harker Heights, TX
20s are rated at 112 but the R/T 22s are rated at 140 mph, so why limit them as much as a standard ram? Makes no sense. Cost me a few races in my R/T when I would hit the limiter
ArmRippinToys
ArmRippinToys
Anchorage, AK
Yeah I know the limiter kicks in because of tires, I plan on going to a different set come
This winter... Something with a higher speed rating, as at as the flashers, yeah I hit like 107 with them on so it doesn't really work
tug
North Charleston SC
I havent had the opp to try with the Jet chip I installed, I dont know if it will help with Top End or not. I was also disappointed when it ended the adventure at 105.
