Buy stage 8 bolts
In what thread pitch ?
If you already have a broken manifold bolt just drill a small hole into it and get an extractor to remove it. Mine came out pretty easy.
Sent from my VS990 using Tapatalk
Grade 8 is plenty good. You'll need something that has a small socket size though. If you get a standard Grade 8 bolt from the hardware store it's probably going to be a 13mm or 14mm head size. You need something that's stepped down to around a 10mm like what comes with the JBA's. Why not just use the JBA supplied hardware? It is more than adequate.
Using obx headers
Not to hijack this thread but what goes into installing the OBX headers? Will I need to lift the engine?
Sent from my XT1080 using Tapatalk
I just bent the tube and relocated it. no need to unbolt it.
