Adams2013
- Jun 2, 2013
- 350
- 21
- 2013
- 5.7 Hemi
I Changed My T-Stat Saturday
Lost A Little Bit Of Coolant
Dident Know The Difference
So I Toped It Off With A Gallon
Of Preston Coolant
Found Out That Was A Bad Idea
So I Went To Dodge Today
Bought The Right Mopar Coolant
$100 For 2 Gallons
I Did Not Know How To Pull Drian Plug On
Rad.. So I Disconected to Bottom Rad
Hose And Flush it For A Couple Min
Also Flushed The Resivor
When I Went To Put The Coolant
It Only Took 1-1/2 Gallons
Then Filled Couldent Even Put Water
So I Drained Some Coolant To Put Some Distilled
Water....Will I Be Ok And Do You Think
That The All The Prestone Is Out?
Only Took Off Bottom Rad Hose
And Left Started For A Little Bit To Let It Heat Up
To Make Rest Of Coolant Come Out
Did I Do Anything Wrong Or Will I Be Ok???
Of Preston Coolant
$100 For 2 Gallons
