ramittome
Here you go. Now figure out witch one of the 2 does this and you have your answer. If you spend money, you want to see some gain.
https://youtu.be/EkpsydS8JXI
I️ just installed an s&b and noticed it has better throttle response and a slight increase in the exhaust sound. It also seems to hold mds a little better at cruising speeds. Otherwise everything else was the same
Well, ... might be relevant if the Hemi used a carburetor. With fuel injections and an Engine Control Module? Not so much.Here you go. Now figure out witch one of the 2 does this and you have your answer. If you spend money, you want to see some gain.
Doesn’t the rams use a different intake sensor then most, so cold air intakes aren’t as effective? I put an S&B intake on my 03, not much effect. I always wonder how much gains that aren’t from the trusty butt dyno...every time I upgrade my truck I tend to drive it harder then normal, then it feels like it’s faster then before...
