Riverbound
- Jan 30, 2015
- 7
- 0
- 2011
- 6.7
About a month ago I noticed my truck was running much hotter than it used to. I have owned the truck for 4 years and rarely did it ever go over 200. Now it seems to sit around 210. And quite often will go up to 220. I took it to my mechanic and they tested the fan clutch and stat and everything was good to go. I had them flush the radiator. We left for a big rv trip (approximately 3000 miles). And it's still running hotter than normal. What I notice is going down the freeway or even climbing big hills it doesn't over heat. But when we come to a stop and let it idle the temps will rise, or coming off the freeway to a stop I will see the temps rise.
I have heard many talk about blown head gaskets but wouldn't I have other symptoms especially towing 15k lbs halfway accross the country.
One other issue I have is when we stop and park the truck and idle (like when checking into a rv park or pulling over on side of road for bathroom stops) the brake and abs light and check 4wd lights will come on. After a couple miles of driving they turn off and everything goes back to normal.
Truck is a 2011 Ram 3500 dually 6.7 4x4
