Hemi on Moonshine..... HECK YEAH!!
Jerseymike
I have been working with Sean aka Hemifever to dial in a tune for my truck. After an extensive on-line search, I came to the conclusion the Hemi would run on E85. I contacted Sean who offered to write a tune. No new fuel pump. No new lines. Same fuel injectors. Just a Hemifever custom E85 tune.
Results: After 2 weeks and 700 miles of driving, testing, and many WOT runs. The truck runs better than ever. Way more power than the 89 octane tune I was running. Why? Because the E85 I'm running is rated at 100 octane, so Sean was able to crank up the timing.
Benefits: 1. Power- I would estimate 15 HP over a 93 tune and 30 HP over the 89 tune I was running. 2. E85 is cheap. I paid $1.69 today instead of $2.69 for Premium fuel. 3. Runs clean- Found a video on youtube that compares gas to e85 showing how clean it burns. Not only will it not build carbon like gas but it will remove the three years of carbon build up already in my engine. 4. Its smells good- Really, pleasant bonus. My truck smells like sweet vodka. 5. Smooth- The truck never ran so smooth, at idle and while cruising, its unreal. 6. Clean emissions- Burns more completely and produces less emissions. 7. Supports American farmers- An added bonus of sending my money to the Midwest instead of the Middle East.
To the naysayers. Modern cars are made with Ethanol in mind. Regular gas is E10 and the EPA approved E15 which will become the standard at a gas station near you. All cars made since 2001 can tolerate Ethanol. Just to be safe I looked up the fuel pump on my truck. Same fuel pump as the 4.7L Ram, which is Flex Fuel. Also, I data logged the Injector pulse width to see if the stock fuel system is keeping up with the extra fuel needed. Short answer. Yes. They do get close to 90% but that is at WOT at 6000 rpms on a modded truck. True, you wouldn't want to run at 90% capacity all the time but for the 1/10 of a second my truck is at 6000 rpms I'm cool with it. And my A/F ratio is dead on 12.7 @ WOT.
Summary: I'm super happy. The truck runs great. The fuel is clean. The only down side is there is 1 gas station near me that carries E85 but I talked to the manager and he has assured me he will continue to carry the fuel.
Thanks to Sean @ Hemifever for taking the time to dial in my E85 tune. Really great work. Just a class act.
PS: Oh yeah. I know we all like to talk about peak HP. But where the Ethanol really shines is the low end torque. Part throttle is where I do 99.9% of my driving, and the low end torque feels like when I went from 3.35 gears to 4.10 gears. Super cool stuff.
UPDATE: The EVIC is way off. I am only getting 13.1 mpg with E85. Still cheaper rhan running 91 or 93 octane fuel.
Youtube video of clean burning E85. https://www.youtube.com/watch?v=-o5D-nic9WM
Jerseymike
Jerseymike
So your tune gives you 15 hp when you go from 89 to 93?!
I don't have a dyno but it is a noticeable gain. The truck is recommended to run 89 from the factory, so there are gains to be had going to 93.
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
Hemi on Moonshine..... HELL YEAH!!
Interested too but I've seen to many threads go back and forth to gain a solid answer like yours. Thanks for telling us about using E85 with no issues. I'm really curious if the fuel lines can handle the corrosion of ethanol?
Sent from the howitzer
dapepper9
Iowa/Nebraska Border
5.9L V8
I'm going be a naysayer for mileage. There's no way in hell you're getting better mileage than with gas when e85 requires about 30% fuel for the same energy content. If you compared a simular tune for 93 you'd be almost guaranteed to see better mileage than now.
GoldDot
Do you have any information that the valves and seats are E85 compatible. I suspect you may experience issues with long term reliability.
Texas
2011 Ram 1500
Interesting. Well I would rather you be the guinea pig, than me. How many miles have you driven with e85?
dapepper9
5.9L V8
Considering modern vehicles are required to be minimum e15 compatible and often e20, i personally wouldn't be worried
Kotta390
Texas
If you are running 12.7 AFR with e85, you are EXTREMELY lean!! Stoich for gasoline is right around 14.7:1 and its 9.7:1 for typical e85. I don't see how it's running that great at WOT with that fueling. Unless I missed something here..
ST-8
His 12.7 was @wot :p
Kotta390
Texas
I know.. Even using the gas scale 12.7 is still pretty damn lean IMO.
Edit* I guess the gasoline scale without the conversion is probably ok just still a bit lean.
charonblk07
Calgary, Ab
F1-A forged 349ci
Again, how I wish we had E85 in Canada, there's no reason that I wouldn't be running it in mine even if the fuel mileage would suffer a hell of a lot more than it already does.
hemifever
Apex, NC
The 12.7 afr statement is inaccurate. That's a gas reading and not accurate on the e85 config.
shane1981
millington tn
so can this be run in the long term or just an every once in a while thing since nowhere in our manual nor anything else states It's safe to run E85
tuned by Jay Greene
Jerseymike
Jerseymike
tuned by Jay Greene
The manual also doesn't recommend an aftermarket tuner, headers, wider tires, ported throttle body, etc.
Jerseymike
Jerseymike
I don't get the gas mileage thing either. I expected a 20- 30% loss. It's a head scratcher. The only thing I can think of is that it is tuned to run on E85 where the flex fuel cars are trying to run on a range of fuels.
Jerseymike
Jerseymike
I have driven 700 miles in the last 2 weeks. Including about 20 0-60 WOT tuning runs.
